Replace the preamp in my acoustic guitar
Postby Amynio » 09 Jun 2017, 08:51
My preamp in my acoustic guitar died after I put the battery in backwards. I need to replace it, and fast. Piezos have incredibly high output impedance (5+ mohm) so a buffer circuit is used to knock the impedance down to a sane level.
I tried building this circuit and while it works, it lacks any sort of bass amplification:
I didnt have a 100k resistor, so r3 is 170k. I also didnt have a .1uf, so c1 is 4.7uf. I tried raising the r2 to 5mohm and it sounded the same. v+ is 9v and vb+ is 4.5v from a voltage divider. OpAmp is TL072
All caps are thin film, not electrolytic
The DI Box next in the chain has an input impedance of 1mohm
Any help or alteratives much appreciated!
Amynio
Re: Replace the preamp in my acoustic guitar
Postby phatt » 09 Jun 2017, 12:23
The original preamp likely had a buffer input then a gain stage and a tone control stage. The better units even try to wipe off the excess high freq bands as that is a big problem with piezo elements.
All you have built is a buffer and so the tone will sound flat and might be tinny, harsh or even scratchy from too much high freq.
I did build a complete preamp for a chap a while back using an old fet circuit and it came out rather well. If you are interested I'll try to dig through my backups and post the circuit.
Phil.
phatt
Have thanks: 266 times
Postby Nikogo » 04 Sep 2017, 16:18
To have a good bass from piezo pickup the preamp need to have about 5 MOhm input impedance.
I made a simple buffer on a single FET. It is in upper right corner of the guitar schematics.
Nikogo
Have thanks: 3 times
Postby Nikogo » 04 Sep 2017, 16:25
Here is the PCB layout for surface mount components:
Nikogo
Users browsing this forum: Steeler [Crawler] and 1 guest
