Middle Freq. EQ Switch
- mecmast
Hi all,
i play a Fender Strat Standart with 3 knobs (volume,tone,tone) and i want to add a switch replacement of one the tone knobs that makes the mids higher and bright my sound.
i think about building a small pcb and using a 2 way switch. i am new at these works.
is there a circuit for this or anybody can help me?
thnx....
thnx....
- TragicTravisty
sounds like a bass cut. try a jag style bass cut. if you insist on a boost, do a treble booster with a lower cutoff frequency.
- TragicTravisty
try the dallas rangemaster, thats the classic one. or a boost with a bass cut, like the sho or something.
- TragicTravisty
no problem. you could also experiment with a switch or something for a fullrange boost or fat boost or something...
