Strat Rubber Grommets
- theblackman
Hi, Does anyone know where i can get some replacement rubber grommets for strat pickups (you know the bit that goes around the screw on each pickup??
The ones on mine are just a thick hospital hose the kind they would use to wrap around your arm to take a blood sample. If that's the ones you seek I think you could find them at a medical or chemistry supply store.theblackman wrote:Hi, Does anyone know where i can get some replacement rubber grommets for strat pickups (you know the bit that goes around the screw on each pickup??
