Blade guitar preamp
Re: Blade guitar preamp
Postby sonnyv2 » 07 Nov 2016, 03:26
thanks, roseblood.
I much prefer to leave the plug in the guitar for convenience (and I'm sure I will often forget to unplug it).
If I were to mod it, I'd add an on/off switch. Or better yet, change the current toggle switch so that center is off (but I suppose that would require installing a switch with multiple contacts).
sonnyv2
Postby roseblood11 » 07 Nov 2016, 05:12
Bad idea. Using that switch would always lead to a very loud popping noise.
Adding an extra switch will work, off course.
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby sonnyv2 » 07 Nov 2016, 16:38
good point. and there might be a delay.
I set the VSC to cut bass and treble in the up position and boost mid in the down position. Effectively, It is a 3-position volume switch. I have Seymour Duncans and the first position cleans them up some and that is most useful to me for chording.
sonnyv2
Postby sonnyv2 » 07 Nov 2016, 16:43
it's a TRS jack that cpnnects ring and sleeve if a cable is plugged in.
how about pulling out the jack one notch and leaving the plug in (actually I feel 3 steps when I insert the jack)?
is it the last click that connects ring and sleeve?
sonnyv2
Previous
