Warwick - Bass schematics
Been thanked: 124 times
Nikifena
Been thanked: 39 times
Post by Nikifena »
everything is good, but there is no pcb schematics.
Actually this is good if someone like to repair warwick
they are not called schematics, they are called pcb-layouts (or pcb-drawings). :wink:
Has thanked: 4411 times
Been thanked: 2139 times
A friend of mine has a Warwick bass. Terrific instrument, he got it second hand. Then after some weeks it suddenly started crackling and buzzing at the strangest moments.
Turned out the pots themselves (casing) were not grounded. :shock: It's ok you can fix it yourself, as Warwick support quickly pointed out, but this type of instruments the electronics should be up to scratch.
quaternotetriplet
Has thanked: 10 times
Post by quaternotetriplet »
can't see the schematic.
