Jackson/Charvel JE1200 schematic
Postby Ice-9 » 03 Sep 2009, 17:50
here is a trace i have made from my charvel model 4 actives in case its of interest to anyone.
Its a vol,tone and mid boost.
Ice-9
Has thanked: 143 times
Have thanks: 361 times
Re: Jackson/Charvel JE1200 schematic
Postby nickthemen » 04 Sep 2009, 00:12
That one with a ? is 220k in the schematic i have.
nickthemen
Has thanked: 32 times
Have thanks: 11 times
Postby Ice-9 » 05 Sep 2009, 22:11
nickthemen wrote:That one with a ? is 220k in the schematic i have.
Does your schematic check out the same as mine. (I RE'd mine from my own guitar, would be great if yours is the same which would verify mine)
Ice-9
Postby jbrew73 » 14 Sep 2009, 23:51
is there any chance someone has the je2000 bass preamp schematic?
jbrew73
Postby nickthemen » 17 Sep 2009, 09:42
Yep my schematic is the same!
nickthemen
Postby rhandy gaye » 08 Oct 2009, 12:03
The following pics/work are not mine so, I can take no credit and don't know of any mistakes. I downloaded them yonks ago and found them on a disc the other day.
I was going to build it but, never got around to it.
For this message the author rhandy gaye has received thanks: 3
alemoralab (04 May 2012, 02:16), mickerules (06 Oct 2012, 18:23), modman (29 Mar 2018, 18:55)
rhandy gaye
Have thanks: 21 times
Postby SPeter » 08 Oct 2009, 19:04
Thanks! :applause:
Is that verified!
SPeter
Have thanks: 76 times
Postby rhandy gaye » 09 Oct 2009, 00:59
Don't know if it is verified but, the layout and traces are very very close to the original (looking at photos), ie this is almost exaclty a je-1200.
rhandy gaye
Postby rhandy gaye » 09 Oct 2009, 01:04
pic from brochure
rhandy gaye
Postby rhandy gaye » 28 Oct 2009, 14:33
found this in google japan
rhandy gaye
Postby kdmay » 05 Apr 2010, 11:10
Just what I've been looking for!!
I am currently building a Keeley Katana pre amp. Awesome pedal, which takes my amp (local Australian built modern plexi) to new heights. I am looking to incorporate a switchable mid boost following the preamp (I might even try to incorporate a pre/post switch, but first things first....).
Anyway, I have a few questions/proposals if someone can help:
- given this will be following a pedal pre amp, I am assuming I omit VR1
- what is the purpose of R2 @ 220k?
- I am going to replace VR2 with a fixed 50k resistor, as I don't need a volume control (level will be dictated by the Katana)
- I am going to omit VR3, as I simply want a fixed mid boost and don't need a mix control. I am assuming I simply take the output of R4 to the Pot of my Katana level control. Although I could wire this post the Katana Pot, which I guess would apply a mid boost to an attenuated signal vs attenuate a preamp/mid boost signal.
Any help on the above would be appreciated!
One for the breadboard tonight.......
Cheers
kdmay
Postby rhandy gaye » 07 Apr 2010, 12:02
what you wanna do sounds cool, i'm gonna have a think about what you've written.
for now though, i wouldn't leave out any pots, but put trim pots in so you can muck around with some settings.
rhandy gaye
Postby kdmay » 07 Apr 2010, 13:54
I've just finished breadboarding it - relatively high component count (for me anyway, say compared to the Katana), so a little time consuming!
Off to the studio tomorrow night to have a listen (and make sure it works/I've done it right)!
Will report back......
kdmay
Postby alemoralab » 04 May 2012, 02:07
a mi me funciono perfecto se escucha muy bien.
alemoralab
Postby 95H » 23 Mar 2018, 20:59
schematic reup possible?
Thanks in advance.
95H
Has thanked: 18 times
Have thanks: 4 times
Postby EddieTavares » 24 Mar 2018, 00:12
I am not sure if it's correct, I found it in a russian forum.
EddieTavares
Have thanks: 13 times
Postby EddieTavares » 24 Mar 2018, 00:29
It works closer to Demeter Fat Control.
EddieTavares
Postby 95H » 24 Mar 2018, 04:49
Thanks. Finally I found that thread too. There ist a hand drawn schem going with the shown PCB further above in this thread all from that Russian forum.
Perhaps someone can verify this schem. OP Amp = LF442CN
For this message the author 95H has received thanks:
95H
Postby Ice-9 » 26 Mar 2018, 18:45
95H wrote:Hi,
Yeah, I traced that hand drawn schematic from my own model 4 charvel the LF442CN is correct, it is a low power IC which helps with the battery power consumption.
For this message the author Ice-9 has received thanks:
95H (26 Mar 2018, 19:21)
Ice-9
Postby jpm83 » 29 Dec 2018, 05:43
I have charvel 475 and it had jrc 062D as opamp.
jpm83
cron
