Hudson Electronic Broadcast  [traced]
Postby tipunk777 » 30 Oct 2015, 15:21
Hello.
I'm a new user of this forum and a french guy, so excuse me if my words are not precise.
I'm looking for this pédal... Image
They say that is inspired by an old RCA broadcast mic preamp. Did anyone have anything about it ?
For this message the author tipunk777 has received thanks:
jtn191 (03 Apr 2016, 20:07)
tipunk777
Re: Hudson Electronic Broadcast
Postby johnk » 23 Dec 2016, 04:38
i have the 9V version but added a charge pump to make it run on 18V internally.
the original is built on veroboard, but here's my PCB layout for it:
For this message the author johnk has received thanks: 2
Manfred (23 Dec 2016, 10:05), Zokk (23 Dec 2016, 13:59)
johnk
Has thanked: 30 times
Have thanks: 252 times
Postby aishabag23 » 23 Dec 2016, 17:00
The guys over at TagboardFX have done a few vero layouts of this one:
http://tagboardeffects.blogspot.com/201 ... dcast.html
aishabag23
Has thanked: 83 times
Have thanks: 10 times
Postby Manfred » 23 Dec 2016, 18:11
Where I can find the schematic of it.
Has thanked: 890 times
Have thanks: 394 times
Postby johnk » 24 Dec 2016, 01:58
i drew up a schematic for my 9V version today. it's the one with the trimpot for the high gain.
Manfred (24 Dec 2016, 03:12), Zokk (24 Dec 2016, 10:20)
johnk
Postby johnk » 24 Dec 2016, 06:16
just an FYI. i built both versions (the newer 24V version and the original 9V version which i own) and i like the original 9V version running on 18 or 24 volts better, so i drew up another PCB & built the older version and it sounds identical to my original.
here's the PCB layout for the one that i prefer:
johnk
Postby Manfred » 24 Dec 2016, 13:40
I have a further question.
Are gain selections of the transistor needed?
Postby johnk » 24 Dec 2016, 17:03
i've tried OC44's, OC71's and OC 75's and all of them sound pretty much the same.
Manfred (25 Dec 2016, 01:00)
johnk
Postby johnk » 25 Dec 2016, 21:31
i just finished my polished & etched 1590B early version 9V Broadcast (with internal 25V charge pump), with all top jacks and a relayed true bypass:
johnk
Postby fuzzbunny » 25 Dec 2016, 22:46
Great work John K.! (as always...)
fuzzbunny
Have thanks: 7 times
Re: Hudson Electronic Broadcast  [traced]
Postby johnk » 30 Dec 2016, 08:49
i forgot one resistor in the above schematic!
here's the correct one:
For this message the author johnk has received thanks: 3
Addy Bart (12 Mar 2017, 00:24), modman (19 Mar 2018, 15:01), ThiagoFaraday (30 Dec 2016, 22:18)
johnk
Postby aishabag23 » 12 Jan 2017, 04:55
johnk wrote:i just finished my polished & etched 1590B early version 9V Broadcast (with internal 25V charge pump), with all top jacks and a relayed true bypass:
[ Image ]
[ Image ]
Just perfect!
aishabag23
Postby gigelmargel » 11 Feb 2017, 21:27
Hello!
Anyone can post the voltages of the transistors, mainly the ones of OC74?
I have only some AC128s and I want to know if are biased right or not.
Thank you!
gigelmargel
Has thanked: 13 times
Have thanks: 14 times
Postby gigelmargel » 27 Feb 2017, 18:32
:scratch:
gigelmargel
Postby V1nce69 » 15 Dec 2017, 16:48
johnk wrote:i drew up a schematic for my 9V version today. it's the one with the trimpot for the high gain.
[ Image ]
I just traced my Broadcast 24V. I unsoldered all diodes on the power supply board to be sure of the type. I made an true to the original vero layout and measured the voltages on both transistors.
Hudson Electronics Brodcast 24V, PG Edition_vero layout.pdf
If you have any questions feel free to ask. I took many pictures. I can post them later.
Vincent
For this message the author V1nce69 has received thanks:
Addy Bart (23 Mar 2018, 06:38)
V1nce69
Have thanks: 57 times
Postby V1nce69 » 16 Dec 2017, 06:00
If you have any questions feel free to ask...
Vincent
And here are all the pictures:
For this message the author V1nce69 has received thanks: 3
Addy Bart (23 Mar 2018, 06:38), modman (19 Mar 2018, 15:02), plush (29 Jan 2018, 10:44)
V1nce69
Postby plush » 29 Jan 2018, 10:45
Hi!
I can verify V1nce69's work.
plush
Has thanked: 20 times
Have thanks: 19 times
Postby teddeeh » 19 Mar 2018, 13:54
Heres a couple of photos i have found of the dual footswitch.
Sadly no underside but could be worrh an experiment or two in decifering this layout, as wehave the original one to go from and fundamentally they are the same.
teddeeh
Have thanks: 6 times
Users browsing this forum: pedalpimps, treptlikus, zamguitar and 11 guests
