Catalinbread - Formula No. 5  [traced]
Gary_W
Post by Gary_W »
Seiche wrote: I know what you mean, sometimes it is, sometimes it's not. The BS170P that the original SHO uses as a 180° pinout from the common BS170 many D.I.Y.ers substitute, for example. So same part number, different manufacturer can still have different pinouts, is what I meant.
More often than not the person doing the layout uses the pinout of the substitutes they have at hand, yet still lists the original part.
Thanks Seiche - I appreciate you taking the time to reply and I'll be especially careful of that in future :)
H.A.
Post by H.A. »
Hello people.
This is my first post in this great forum, which I always read.
I just wanted to upload a PCB I made for Formula 5.
BOM, PCB and Layour on *.rar file.
PCB is verified, put it together with a COT50 from La Revolution Deux.
Pics:
Half-way through the wiring!
Etching
Layout preview of the PCB:
Formula 5.rar
BOM, PCB and Layout.
(68.9 KiB) Downloaded 272 times
mganzer
Has thanked: 32 times
Been thanked: 26 times
Post by mganzer »
Hi Guys; Anyone put the hands in one of that? someone knows what changes from formula n5?(aside from the obvious tone stack changes)?
Cheers
MG
throni3fsb
Post by throni3fsb »
mutetourettes wrote:...
If anything, fed with humbuckers this pedal has too much gain. Any suggestions for reducing the gain?
Hello, schematic painters and signal tracers,
first, i wanna thank you for your good work. I built the Formula five last night and it worked immediatly. However, i wondered, why it clips a little bit hard with gain all down, when played hard. Especially with humbuckers, as you may have expierienced. With LTspice, i simulated it and changed the 62k input resistor to higher values, and changed it on my Formula 5 to 1000k. I've seen on the pictures on the first page of this thread, that it should be 620k instead of 62k, because the rings are blue red orange instead of blue red red. Could someone please verify this??
These days i will try to match the transistors. For that purpose, are there some recommended values, or is it ok as long as the transistors are in a similar region??
Greetings
Thomas
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
It's pretty obvious that it`s blue-red-orange, but that means "62k". 620k would be blue-red-yellow...
Does it sound better/closer to the original pedal with the 620k?
In another version of my vero layout I noted "C1 is 470pF, not 47pF" - but I don't remember, where that came from. Was it mentioned in the thread before?
induction
Has thanked: 61 times
Been thanked: 116 times
Post by induction »
roseblood11 wrote:In another version of my vero layout I noted "C1 is 470pF, not 47pF" - but I don't remember, where that came from. Was it mentioned in the thread before?
Final answer is here with discussion throughout that page.
throni3fsb
roseblood11 wrote:It's pretty obvious that it`s blue-red-orange, but that means "62k". 620k would be blue-red-yellow...
You are right. It is orange, but for some reason i had another factor in mind. so it is 62k.
I can't say that it is closer to the original. But for me, it works better because now i control the clipping only with the gain knob, not with my guitar volume knob anymore. I simply didn't like it, when the first clipping stage came to clip. Of course, the overall gain is lower with this modification. I don't know whether i will keep the mod or not, i will test it for a while.
Greetings
Thomas
mutetourettes
Post by mutetourettes »
So it seems there was a Mark II catalinbread formula no5 with (reportedly) some differences in circuit/components (and then a Mark iii, which was just a paint job supposedly) - does anyone have any idea about the differences?
(I'm not talking about the newer 5f6 by the way)
Mark
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Yeah roseblood the correct value is 470p It was my pedal originally and I made the mistake labelling it 47p, but that error was cleared up and the correct value was definitely 470p
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
Thought I already posted this but must have missed it
matt239
Has thanked: 60 times
Been thanked: 5 times
Post by matt239 »
+1
I have an original Formula 5, I'm curious what's different here. - Is it just the tone stack?
- Sounds nice.
Motter
Been thanked: 121 times
Post by Motter »
I built this pedal with an extra footswitch for the 2M resistor (thanks IVIark!), but the box I have is drilled for four pots instead of three so I'm wondering what I can put in that fourth spot.
So far I'm thinking a voltage starve or a bass cut. What do you guys think would be more useful? Alternatively I could make that last pot into a boost pedal (sho or rangemaster), but I really like the built in boost effect of switching out the 2M.
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
Anybody seen gutshots or (shock horror) own one? I'm tempted to buy one with a view to tracing and I'm interested in finding out if they are SMD
roseblood11
BUMP
Would really like to see the Formula 55 traced...
roseblood11
This pedal is incredible, I'd really like to see it traced!
POTL
Has thanked: 58 times
Been thanked: 67 times
Post by POTL »
There is Formula №5
Formula No 5 Fixed.png (7.3 KiB) Viewed 3118 times
Presence control will look something like this
Although in an ideal it would be to see the scheme
https://s26.postimg.org/nd6u7z4ll/SC_1.png
roseblood11
I built that years ago...
The Formula No.55 is a completely different circuit
nicothyrael
Post by nicothyrael »
I'm making a Dirty little secret to practice until someone publish the schematic of this one.
I hope it will be soon, as I don't have one I can't help too much.
roseblood11
In most european countries it's possible to buy a pedal online and then to send it back without any cost. Off course, that's not a nice way...
mr coffee
Has thanked: 86 times
Been thanked: 14 times
Post by mr coffee »
Has anybody seen the insides ? The demo sounds pretty good.
mr coffee
