3PDT and power
Frequently asked questions regarding powering your pedal.
3PDT and power
Postby sbanacho » 07 Nov 2013, 22:52
Kind of a n00b question, but why when we use a 3PDT do we use one of the poles to turn on/off the LED? Why not instead turn on/off power to the whole circuit?
sbanacho
Re: 3PDT and power
Postby Nocentelli » 07 Nov 2013, 23:49
Have you ever disconnected and reconnected power to a pedal when it's plugged into an amp? Massive pop.
Nocentelli
Has thanked: 892 times
Have thanks: 854 times
Re: 3PDT and power
Postby beedotman » 08 Nov 2013, 09:21
Nocentelli wrote:Have you ever disconnected and reconnected power to a pedal when it's plugged into an amp? Massive pop.
Is there any way to avoid that? On Off switch to disconnect battery is cool feature on pedal, but this pop is uncool...
http://www.turretboard.org 4 life!
beedotman
Has thanked: 428 times
Have thanks: 410 times
Re: 3PDT and power
Postby Nocentelli » 08 Nov 2013, 16:30
You could have a simple SPST switch to break the power connection, but it would pop if you forgot to turn the amp down/off before flicking the switch. A power off switch is only really neccessary if you use batteries and don't want to unplug the input cord to power off the pedal. I can't see the point in lnking this to the footswitch: Quite apart from the pop, many pedals would not work for a second or two after switching on as the capacitors need to charge, and some modulation effects need a bit of time for the LFO to get going.
Nocentelli
Re: 3PDT and power
Postby beedotman » 08 Nov 2013, 16:48
yeah, I used rotary switch to disconnect battery when input jack is plugged, I thought there is some way to avoid this pop...
beedotman
Re: 3PDT and power
Postby Nocentelli » 08 Nov 2013, 17:06
I'm sure there's some sort of "soft power on" circuitry out there, I just haven't come across it yet.
Nocentelli
Return to Power
