Alpha with only E105 on back?
Postby chicago_mike » 08 Jun 2012, 22:37
E105 is on the back of some pots on an amp.
105...that would be 1Meg? :scratch:
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 296 times
Re: Alpha with only E105 on back?
Postby TV-Set » 20 Jun 2012, 20:28
chicago_mike wrote:E105 is on the back of some pots on an amp.
you could simply use a multimeter to check those pots :thumbsup
TV-Set
Has thanked: 25 times
Have thanks: 6 times
Postby Ice-9 » 16 Nov 2013, 17:28
Yup ! I would think so, but wouldn't know about the taper.
Ice-9
Has thanked: 143 times
Have thanks: 361 times
Postby galmar » 16 Nov 2013, 22:48
You can also measure the resistance between legs 1 and 2, for say 5-10 positions of rotation, and then see how it goes. Or just measure it while rotation is 50% - if it measures half the total resistance, it is linear, if it is roughly 10% of the total value it is log. If it is more than 50% it would be reverse log. :)
galmar
Have thanks: 10 times
Return to Resistors
