Alpha with only E105 on back?
Posted: 08 Jun 2012, 21:37
by chicago_mike
E105 is on the back of some pots on an amp.
105...that would be 1Meg?
Re: Alpha with only E105 on back?
Posted: 20 Jun 2012, 19:28
by TV-Set
chicago_mike wrote:E105 is on the back of some pots on an amp.
you could simply use a multimeter to check those pots
Posted: 16 Nov 2013, 16:28
by Ice-9
Yup ! I would think so, but wouldn't know about the taper.
Posted: 16 Nov 2013, 21:48
by galmar
You can also measure the resistance between legs 1 and 2, for say 5-10 positions of rotation, and then see how it goes. Or just measure it while rotation is 50% - if it measures half the total resistance, it is linear, if it is roughly 10% of the total value it is log. If it is more than 50% it would be reverse log.
