Can I replace SMD by normal resistor?
Postby Dulouz » 08 Jun 2013, 20:43
Hey Guys!
I was replacing the footswitches on my DL4. While I was disconnecting one of the mountain switches my pliers slipped and I nicked the R29 resistor. I got everything wired up, but now that switch is the only one that doesn't work. Could the damage to the resistor be the problem? I've quadruple checked all of the solder joints and everything looks good.
Here's a photo:
Dulouz
Re: DL4 SMD Resistor
Postby bajaman » 09 Jun 2013, 00:14
yes :wink:
Has thanked: 443 times
Have thanks: 1515 times
Postby Dulouz » 09 Jun 2013, 00:21
Ha! Thanks!
Can you replace SMD components with through hole?
Dulouz
Postby IvIark » 09 Jun 2013, 00:37
Yes, you'll just need to solder the leads to the pads. It'll be a bit fiddly but do-able.
IvIark
Has thanked: 668 times
Have thanks: 680 times
Postby Duckman » 09 Jun 2013, 01:29
looks like 1/8w resistor got almost the same size... almost :hmmm:
Duckman
Has thanked: 368 times
Have thanks: 126 times
Postby Güero 2.0 » 09 Jun 2013, 01:32
Here, code 1001
"Come squeeze and suck the day.Come Carpe Diem baby!"
Güero 2.0
Have thanks: 25 times
Postby Ice-9 » 09 Jun 2013, 09:20
Just stick on a 1k through hole resistor, use a soldering iron to try and catch both sides of the smd resistor at the same time and it should just stick to the tip of the iron when you push the iron to remove the resistor.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby Dulouz » 09 Jun 2013, 14:49
Thanks for the help everyone!
I had an extra 1K resistor handy and I soldered it to the pads with no problem.
Now all the switches work perfectly!
Dulouz
Return to Resistors
