Coupling capacitor response
- Mbas974
Hi, can anyone explain to me why using an output coupling capacitor of 47uF instead of 4,7uf the sound results more open ? (both of them make a RC filter with a 100K resistor, so both let pass everything above the 0Hz). I'm powering the circuit (booster with IC) with 9V. Maybe the output signal is to wide that 4,7 can't manage ? Tx
