Code: Select all
which gives you:
Link
Has thanked: 3173 times
Have thanks: 597 times
Code: Select all
Code: Select all
Hope this helps! :D
Limadito
Link
Duckman
Has thanked: 369 times
Have thanks: 131 times
Duckman
Limadito
Code: Select all
Warning
Code: Select all
Warning
Code: Select all
/* Custom styles
.video-wrapper {
   width: 640px;
   max-width: auto;
.video-container {
   position: relative;
   padding-bottom: 56.25%;
   padding-top: 30px;
   height: 0;
   overflow: hidden;
   position: absolute;
   top: 0;
   left: 0;
   width: 100%;
   height: 100%;
The bbCode in use is
Code: Select all
And HTML Replacement is
Code: Select all
<div class="video-wrapper">
<div class="video-container">
</div>
</div>
Limadito
Return to Capacitors
