Electro caps orientation
Postby Duckman » 26 May 2009, 00:56
I always read about "correct" electro caps orientation when you are designing a circuit, I mean, all positives (or negatives) leads pointing to the same PCB side. But, honestly, 99% of the stompboxes (standard or boutique) and/or photos I see, comfirm to my eyes that this is not a "golden rule". I wanna know if somebody has noticed or experimented a real improvement or even a perceptible difference between circuits that have "correct" or "incorrect" caps orientation.
Thanks to all!
Duckman
Has thanked: 368 times
Have thanks: 126 times
Re: Electro caps orientation
Postby bajaman » 26 May 2009, 01:26
polarised electrolytic capacitors should always be connected with their positive terminals to the most positive dc voltage potential points when placing them in the circuit. For example - when using a polarised electrolytic capacitor as a coupling capacitor from a npn emitter, or n channel jfet source, being run as a buffer from a positive dc supply voltage, this point will usually be at approximately half the supply voltage (+4.5v dc when using a +9v dc supply), and so you should connect the positive terminal of the electrolytic capacitor to this point. The other terminal usually connects to a resistor (or potentiometer volume control etc.) which has it's other terminal; connected to ground and so is at zero dc potential.
Failure to observe the correct polarity will result in non linear distortion (not good!!) and possible destruction of the electrolytics dielectric (explosion if run from very high voltage :slap: )
Hope this helps :wink:
Has thanked: 436 times
Have thanks: 1497 times
Postby Duckman » 26 May 2009, 01:47
Tkx, Bajaman! Your posts are always very usefull, and one of my actual proyects are based in your info about Musicman Stingray pre. But, about the electros, I'm talking about phisical orientation, not electrical orientation. Any sonical or ellectrical advantage by placing all electros facing the same side? If not, I think I can save a lot of traces! Got the piont?
Big Thanks!! :thumbsup :thumbsup
Duckman
Postby bajaman » 26 May 2009, 02:12
Any sonical or electrical advantage by placing all electros facing the same side?
No - none whatsoever :wink:
Postby JiM » 26 May 2009, 09:37
Duckman wrote:Any sonical or ellectrical advantage by placing all electros facing the same side?
The only advantage is from a manufacturing point of view : it's less error-prone, and easier to check.
It might also be an unintentionnal side effect of all negative leads being connected to the same ground strip. :wink:
JiM
Has thanked: 30 times
Have thanks: 37 times
Postby Duckman » 27 May 2009, 03:35
Well, since my level of manufacture are very low...[smilie=a_bluesmile.gif] what a relief to me! I found myself few times re-tracing and re-re-tracing designs only to keep electro caps "well" oriented. Any way, it's not an error in the end and, in certain way, looks neat, like those guys who place components very simetrically (only Antelope come to my mind now) but, this is another theme.
Tkx JiM!
Duckman
Return to Capacitors
