Is this cap a non-polar 1uf or 0.1uf?
any ideas?
which cap is this?
- dtjesus
- Untitled.jpg (28.75 KiB) Viewed 1194 times
- Dr Tony Balls
my guess is 10pF, but get another opinion. The numbering scheme is a little out of order looking, but normally the 3 numbering scheme works like so:
cap will say "XYZ"
X = first number of capacitance
Y = second number of capacitance
Z = number of zeroes following the first two numbers
and it will provide the capacitance in PICOfarads. so for example...
104 = 100000pF = .1uF
332 = 3300pF = .0033uF
cap will say "XYZ"
- andre
- my favorite amplifier: Hughes & Kettner Statesman Quad
- Completed builds: Dist + overdr.: Distortion+, BSIABII, Shaka III, Bluesbreaker, Box of Rock, Highway 89, DS-1, Proce Rat, Omnidrive, TS808, Bluemagic, Fulldrive 2, big muff
Delay: DM-2, Rebote 2.5, PT-80
Modulation: Ross Phaser, Small Clone, CE-2, Zombie chorus, FL-301, Easyvibe, Ultraflanger
Compr.: Dod280, Dynacomp
the rest: SG-1, Sparkleboost, BAJA CX-3 leslie simulator - Location: Netherlands
- Been thanked: 6 times
It's a 0.1uF/100V capacitor
I have a lot of capacitors that have this kind of notation.
- dtjesus
thanks guys for the quick response.
andre, you are right. i always assumed the lot of these caps i had to be 0.1uf until yesterday when i began to doubt if its a 1u non-polar. scary thought as i would have had to pull these out of all my previous builds :p
its a confusing marking and i cant really seem to find any info online on this type of marking
