dot on germanium transistor
PostPosted: 13 May 2014, 21:02
by copachino
what does it mean a red dot on the transistors?? i have seen many dealers that says that their transistor have a red dot, but im not sure what ir means
Re: dot on germanium transistor
PostPosted: 14 May 2014, 09:37
by tonyharker
A red dot or other colour dot on the side of the transistor case ONLY denotes the collector lead.
A red spot elsewhere on older transistors - usually on the top - used to indicate the goodness/gain/frequency response of the device. There were red spots - the best, white spots - good, and unmarked low gain. The manufacturing processes of early transistors was not as exact/precise as modern ones.
