looks interesting!
http://www.elisanet.fi/dncmrc/rolled_cap.htm
http://www.linux-host.org/energy/scapacit.htm
http://www.instructables.com/id/Flux-Capacitor/
diy capacitors
- RnFR
- Jarno
- my favorite amplifier: Something nice
- Completed builds: Alembic-like state-variable and sallen-key filter preamps
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D - Location: Rosmalen, NL
- Has thanked: 27 times
- Been thanked: 81 times
This guy in Israel built his own 60' Jazz Bass, right down to the PIO cap, check it out: TDPRI.com thread
Anyways, it looked so easy that I didn't think it would work, so I tried myself
I glued aluminiumfoil strips onto paper strips, rolled them, and soaked them in mineral oil (the stuff they use to lubricate sewing machines).
First try:
Not very successful, because the alu foil shorts, I did get enough capacitance on the meter to make me want to try again.
Try and try again:
620nF! Not bad, it does leak a bit (DC resistance 1,5M) so I wouldn't use it in a tube amp. Also, sealing is important, I left it hooked up to the meter unsealed and checked every couple of days, as the oil leaked away, so did the capacitance.
First try:
Try and try again:
- RnFR
wow Jarno, that is quite a thread! thanks for the link and the pics of your experience giving it a try. do you think you'll ever try actually potting one fully and finishing it off? and do you know how to adjust the amount of capacitance?
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
You mean the build thread of that Jazz Bass? Yes, that is one dedicated guy right there!
I am not sure I will be potting diy caps anytime soon, although I am curious to see if they sound different/ better. You can adjust the capacitance by either the distance between the conductors, the surface area and the dieelectricum (in my case paper). I have found formulas to calculate the capacitance of flat plate capacitors, but my second test ended up much higher, so there is probably a different set of formulas involved.
