[Tips & Tricks] Perfboard Building
Postby drmathprog » 26 Feb 2008, 15:24
I'm inspired by the Eternity and King of Tone perfboard projects. Can someone point me to a tutorial or suggest techniques for soldering a perfboard project? Specifically, I'm not clear on how I can solder the components on one side to the wires on the other side.
drmathprog
Re: Perfboard Build Tips?
Postby ieatyouforbreakfast » 26 Feb 2008, 22:11
don't cut the leads to the components and use the extra lengths as traces.
ieatyouforbreakfast
Have thanks: 10 times
Postby drmathprog » 26 Feb 2008, 22:19
Thanks. Seems obvious, but it didn't occur to me until I read your post. :D
drmathprog
Postby Dave Simpson » 27 Feb 2008, 06:51
Dave Simpson
Postby drmathprog » 27 Feb 2008, 15:34
That's perfect; I don't know why I couldn't find it! Thanks!
drmathprog
Postby Alex C » 29 Feb 2008, 04:41
The Tweak-O project has hole-by hole instructions, and shows both sides of the board at several stages. It was my first build, and I was very fortunate to have this project as a guide.
-Alex
Alex C
Postby ubersam » 29 Feb 2008, 08:30
I create a layout for a pcb then use that as a guide when building on perfboard.
ubersam
Have thanks: 8 times
Postby drmathprog » 29 Feb 2008, 12:35
Thanks Alex. I've never seen those push in terminal posts before. Where did you find those?
drmathprog
Postby Alex C » 29 Feb 2008, 23:48
drmathprog wrote:Thanks Alex. I've never seen those push in terminal posts before. Where did you find those?
Steve at Small Bear Electronics (who created the Tweak-O tutorial) calls them "flea clips" and sells them on his site here.
Alex C
cron
