[Tips and Tricks] PCB routing
Re: PCB routing tips and tricks
Postby RnFR » 23 Oct 2008, 19:05
just realized it's only the first 100 pages. the only thing that i think i would really miss is the chapter on Eagle output. looks like it might be a good book to just throw down the cash for anyways.
edit: dammit! it cuts off right in the middle of explaining how to create components in eagle. the part i really wanted to see!
Has thanked: 150 times
Have thanks: 174 times
Postby Barcode » 23 Oct 2008, 21:07
FYI, the image DIYLC puts out for the traces is at 72 dpi. If you use any grapchis program that let's you print in a different dpi, you can change it to 200.25 dpi and it will print exactly the right size.
Barcode
Have thanks: 35 times
Postby marshmellow » 24 Oct 2008, 15:50
RnFR wrote:just realized it's only the first 100 pages. the only thing that i think i would really miss is the chapter on Eagle output. looks like it might be a good book to just throw down the cash for anyways.
That is covered in the PDF manual you can download in a step by step tutorial. Not so complicated at all that you would need a book for that.
marshmellow
Have thanks: 124 times
Postby RnFR » 25 Oct 2008, 16:39
here's a big list of pcb tools:
http://www.olimex.com/pcb/dtools.html
Postby RnFR » 28 Oct 2008, 17:02
