cacophony wrote:ei guys, check this out:
I just used high quality glossy paper in doing the transfer. Just take note that the print must be done through a laser printer or a powder photo copier. It's a lot cheaper than using laser photo paper or Press 'n Peel!
puppiesonacid wrote:kierc,that looks awesome!
kierc wrote:Wow thanks!![]()
I can't take credit for the artwork though, They're images from a Sin City comic that I played around with...
mikitz wrote:There was a package of high quality laser photo paper on sale for cheaper than anything else so I went ahead and used it for my first couple of etches.... bad idea.. as it turns out the ironing process transfers the toner very well but this type of laser photo paper leaves behind a sticky layer as well that the etchant has a problem getting through. I was getting okay results with about 30 minutes of etching.
Then after some internet research I tried the magazine paper (you can buy glossy laser magazine paper at the St*ples) and the result was much better. The ironing transfer took about 10 minutes on a 1590a and 5 minutes to etch! I would definitely recommend the magazine paper over laser hoto paper. I understand others have had great success with feeding *inkjet* photo paper into laser printers.. but I don't want to mess up my printer so I don't have the nerve to try it.
mikitz wrote:Sorry I wasn't clear, I'm using blank glossy magazine quality paper designed for laser printers. The package says "HP premium presentation laser paper". It is about the thickness of regular paper but glossy on both sides. It is working very well for me.
The laser photo paper (st*ples brand laser photo supreme) left a transparent gummy film that wouldn't come off without damaging the toner layer. This is after soaking and rubbing. The presentation paper is cheaper than the inkjet photo paper here in Ontario.
