Small drill press that doesn't need fixed to surface?
Frequent question about finishing your stompbox: painting, etching, clearcoating, lettering, etc...
Postby Jonotron » 15 Aug 2013, 21:14
Hi there,
Does anyone have any recommendations for a small drill press for drilling enclosure holes for sockets, switches etc (preferably available in the UK) that doesn't need to be bolted or fixed to a floor or bench? I don't have a dedicated workshop and would like to be able to remove the drill for storage when not in use without having to unbolt it.
Many thanks for any suggestions!
Jonotron
Re: Small drill press that doesn't need fixed to surface?
Postby bato001 » 15 Aug 2013, 22:06
Jonotron wrote:Hi there,
A rotary tool from craftsman or a dremel with a plunge router attachment work fine for PCBs. I have never used the rotary tool for drilling enclosures though.
Dremel Rotary Tool: http://www.sears.com/dremel-300-series- ... ockType=G9
Dremel Rotary Tool plunge Router attachment: http://www.sears.com/dremel-plunge-rout ... 10?prdNo=1
Not sure where you would pick these up in the UK, but I am certain this tool or something similar is widely available.
bato001
Has thanked: 46 times
Have thanks: 57 times
Postby astrobass » 15 Aug 2013, 22:26
It's precisely the smaller ones that DO need to be bolted down somehow - they don't have a heavy enough base to be stable otherwise.
Anyhow, just get a big ol' vise and clamp it down. Not permanent, but stable enough.
I never tried a rotary tool. I will say that being able to just put a hole in a box any time I want to has been well worth the $120 I spent between the drill press and then stepping bit.
astrobass
Has thanked: 50 times
Have thanks: 72 times
Postby Jonotron » 16 Aug 2013, 17:10
Thanks for your input, I think I may go down the route of buying a folding workbench with the bolt holes ready drilled and look at a small drill press of some description. I work in a high school so use the pillar drills in the Metalwork rooms which are awesome but would like my own little facility!
Jonotron
Return to Enclosure Finishing
