Wire measurment
All frequent questions on switching: true or not true bypass, transistor-based or mechanical.
Been thanked: 909 times
This might be stupid question, and probably is...
How to measure 38/40/42AGW wire thickness? I can't do it with typical ruler, do I :blackeye
I'm going to dissemble few popular inductor clones to check what construction do they have - type/style of wiring, wire diameter, and obvious things before I do that (coil diameter, inductance and resistance).
I'm going to build a simple coil winder and start rolling my own crap
lolbou
Has thanked: 308 times
Been thanked: 225 times
Post by lolbou »
Vernier caliper! I just can't live without one...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
deltafred
Has thanked: 814 times
Been thanked: 306 times
Post by deltafred »
lolbou wrote:Vernier caliper! I just can't live without one...
+1
Go for the digital ones, they measure in imperial and metric at the push of a button.
http://www.ebay.co.uk/itm/6Inch-150mm-D ... 2a1e982d23
nice, thanks guys :thumbsup
DrNomis
Has thanked: 98 times
Been thanked: 279 times
Post by DrNomis »
You could also buy a wire-gauge.... :thumbsup
link me example Simon
DrNomis
Post by DrNomis »
I think this is probably what you're after, you may be able to order one of these online from America, I should get myself one too.... :thumbsup
http://en.wikipedia.org/wiki/Wire_gauge
deltafred
Post by deltafred »
DrNomis wrote:I think this is probably what you're after, you may be able to order one of these online from America, I should get myself one too.... :thumbsup
They are good, but only for checking wire or plate gauges, I have one and never use it. It just acts as ballast to make my toolbox heavier..
A vernier calliper is good for measuring length, depth, diameter etc. Once you get one you wonder how you ever managed without.
DrNomis
Post by DrNomis »
I've been meaning to get myself a good vernier caliper,deltafred.... :thumbsup
CHEEZOR
Has thanked: 42 times
Been thanked: 50 times
Post by CHEEZOR »
For such thin wire thicknesses I would think that the caliper would be better than the wire gauge. Just my 2 cents.
lolbou
Post by lolbou »
deltafred wrote:A vernier calliper is good for measuring length, depth, diameter etc. Once you get one you wonder how you ever managed without.
Yes again!! Think screws (metric or imperial?), holes diameters and drill bits, PCBs, enclosures, components, whatever... :horsey:
littleBloona
Post by littleBloona »
In the last millenium old hams just wound n windings tightly on a round pencil and measured the width with a ruler. Then they divided the outcome by n. :idea:
