DIY Shielded wire?
All frequent questions on switching: true or not true bypass, transistor-based or mechanical.
TV-Set
Completed builds: Silicon FF with tone control, Proco RAT, MXR Dist+, BMP, Phat Pig (custom 6 controls fuzz pedal)
Has thanked: 18 times
Post by TV-Set »
Hullo!
Where I live it's kinda difficult to find shielded wire...
Could I just:
> take ordinary solid core gauge 24 copper wire in its plastic tubing.
> wrap it nicely with a long strip of tin foil.
> put it all in a heat shinkable tubing.
Sort of a thin home made satellite dish cable or similar
Would that work?
Dr Tony Balls
Been thanked: 172 times
Post by Dr Tony Balls »
Not really. aluminum foil tears so easily that it would just rip off when you tried to solder the shiled to ground. Also, it might not solder too well either, but thats another thing.
DaveKerr
my favorite amplifier: Ampeg M-15
Dynacord Preference 500
Completed builds: Fuzz Face (2)
Tonebender MKII (3)
ROG Tri-Vibe
PAiA Ring Mod kit
Ring Mod based on Tim E schematic (2)
Rangemaster
CNO
ROG Splitter-Blender
Clari (Not) cubed deluxe
Has thanked: 53 times
Post by DaveKerr »
You could add a bare copper wire outside the aluminum foil and inside the heat shrink, then solder the bare copper wire to ground. Dr Balls is right about soldering directly to aluminum foil not working.
... multiple LFO waveforms (saw up, saw down, triangle, square); a more flexible envelope with attack/release controls as well as inverted envelope. I am afraid it will have more knobs than the TGP annual convention - frequencycentral
TV-Set
Post by TV-Set »
DaveKerr wrote:You could add a bare copper wire outside the aluminum foil and inside the heat shrink, then solder the bare copper wire to ground. Dr Balls is right about soldering directly to aluminum foil not working.
That's just the thing I was doing here... 1st layer of tin foil then I twisted a bare copper wire around the thing and wrapped it all with another layer of foil then put it inside a heat shrink :thumbsup now I have easy access to both the signal wire and the gnd or whatever it's called. still have to test it and see what's it like.
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
why not just cut up a cheap guitar cable?
TV-Set
Post by TV-Set »
Seiche wrote:why not just cut up a cheap guitar cable?
Speaking about thinking out of the box, I just found some old headphones with big chunky wire (much thinner than guitar cables). Only has a net of copper wires around the signal core, no foil, that ok?
Seiche
Post by Seiche »
isn't that exactly how guitar cables are made? of course there is insulation between the core and shielding. Just saying that shielded cable and guitar cable are basically the same.
TV-Set
Post by TV-Set »
I dunno, I never took apart a guitar cable, all the knowledge I have about shielded cables is based mostly on big-ass audiofile signal cables my father buys for his hi-fi system or those cables you use for a satellite dish, both have multiple coatings and therefore are a bit different from ordinary shielded wires I guess :mrgreen:
