resistor from lug 3 to lug 9 on 3pdt?
All frequent questions on switching: true or not true bypass, transistor-based or mechanical.
Postby razorblades » 04 Apr 2014, 04:15
I've seen it in photos on the web, where there would normally be a jumper, but can't find any explanation of it's purpose. Possibly switch pop?
razorblades
Re: resistor from lug 3 to lug 9 on 3pdt?
Postby Nocentelli » 04 Apr 2014, 06:02
It's most likely a zero ohm resistor (single black stripe) used in place of a jumper for the bypass path. Probably used because it's marginally easier to solder in place and looks cool.
razorblades (04 Apr 2014, 07:08)
Nocentelli
Has thanked: 893 times
Have thanks: 855 times
Return to Switching & Wiring
