4 effects in 1 box
Putting two effects in one box almost looks too easy, but you will save a lot of time reading the frequent questions before starting such a project...
4 effects in 1 box
Postby benobo » 27 Jan 2012, 12:46
Hello All,
I am planning to build 4 effects in 1 box (OD>Comp>Delay>Disto) with one input and one output. I am concerned about the loss of signal when all 4 effects will be switch on.
Would anyone advice me to build as simple Jfet buffer between each effects? or to add a clean boost at the end of the chain?
benobo
Has thanked: 42 times
Have thanks: 11 times
Re: 4 effects in 1 box
Postby asatbluesboy » 27 Jan 2012, 15:01
I would add Jack Orman's Super Buffer at the end of the chain. The internal connections would hardly cause too much signal loss when on bypass, and most effects have a quite low output impedance (which would prevent any further signal loss).
...collectors together and emitter to base? You're such a darling...
ton.
For this message the author asatbluesboy has received thanks:
benobo (27 Jan 2012, 15:02)
asatbluesboy
Has thanked: 41 times
Have thanks: 2 times
Return to Multi-Effects
