Putting two effects in one box almost looks too easy, but you will save a lot of time reading the frequent questions before starting such a project...
Code: Select all
which gives you:
Link
Has thanked: 3217 times
Have thanks: 602 times
Code: Select all
Code: Select all
Hope this helps! :D
Limadito
Link
Duckman
Has thanked: 369 times
Have thanks: 141 times
Duckman
Limadito
Code: Select all
Warning
Code: Select all
Warning
Code: Select all
/* Custom styles
.video-wrapper {
   width: 640px;
   max-width: auto;
.video-container {
   position: relative;
   padding-bottom: 56.25%;
   padding-top: 30px;
   height: 0;
   overflow: hidden;
   position: absolute;
   top: 0;
   left: 0;
   width: 100%;
   height: 100%;
The bbCode in use is
Code: Select all
And HTML Replacement is
Code: Select all
<div class="video-wrapper">
<div class="video-container">
</div>
</div>
Limadito
Postby PegasusOne » 12 Sep 2019, 14:48
Embed videos & playlists
1. On a computer, go to the YouTube video you want to embed.
2. Under the video, click SHARE .
3. Click Embed.
4. From the box that appears, copy the HTML code.
5. Paste the code into your blog or website HTML.
PegasusOne
Return to Multi-Effects
