Important: boutique sections closed... DMCA kicks in.
Have a look here for general information about the forum, rules and announcements.
Re: Important: boutique sections closed... DMCA kicks in.
Postby pedalguru » 08 Aug 2011, 13:41
Maybe you can tell me, where there is a current mirror used in the Retro Channel design ?
It speaks volumes that neither you nor mictester can see it for yourselves.  Maybe it's because it's something you haven't seen before, and you are therefore not familiar with it?
But wait, doesn't that defeat your argument that it is in no way a novel circuit topology?  Clearly in some part it must be, otherwise, why so confused?
And please enlighten us mictester:  How well does the original MKII tonebender circuit work if you simply replace the germanium transistors with silicon transistors?
Exactly the same, but with no temp issues?  Or perhaps, not too well, actually?
We both know it's the latter.  So then explain to us all how a bias scheme that makes it work correctly can be a waste of parts and battery current, as you claim.
On another note RnFr claims to build and sell pedals.
Under what brand?
Are these devices original designs or lifted designs obtained from this board?
It's a fair question I think.
Is it that you share ideas but don't sell designs shared here with the general public for financial gain, or do you have a company that builds and sells the designs of others?
If you do lift designs and sell for profit it would make you no better than the brands you profess to debunk would it?
Just a thought
pedalguru
Postby pedalguru » 08 Aug 2011, 13:53
BTW, the Fuzz Face part is NOT temperature stabilized, only the first transistor stage, can you tell me why ?
The fuzz face circuit topology uses negative DC feedback to maintain bias stability, whereas there is no DC negative feedback around the first transistor stage, making it prone to DC bias drift with temperature.
You knew that and were just testing me, right?
pedalguru
Postby jreeves47 » 08 Aug 2011, 13:58
Dude it's a silicon tonebender
Go dazzle tgp with your germanium voiced circuit theory current mirror topology.
jreeves47
Has thanked: 41 times
Have thanks: 20 times
Postby minnow » 08 Aug 2011, 13:59
pedalguru wrote:Are these devices original designs or lifted designs obtained from this board?
Just a thought
RnFR's The Toe Cutter: http://www.freestompboxes.org/viewtopic ... 678#p39950
:secret: Please search - you've been advised before, a few times already, by a number of people, on a few different occasions.
minnow
Has thanked: 26 times
Have thanks: 19 times
Postby tube-exorcist » 08 Aug 2011, 14:01
No, I only know that if you build a Fuzz Face with BC108 and you touch the first transistor the collector voltage of the second transistor will drift. Not so much as with germanium, but it will drift. Try it for your own.
tube-exorcist
Has thanked: 210 times
Have thanks: 77 times
Postby tube-exorcist » 08 Aug 2011, 14:07
Therefore I asked a guru, but sadly no reasonable answer.
pedalguru wrote:But wait, doesn't that defeat your argument that it is in no way a novel circuit topology?  Clearly in some part it must be, otherwise, why so confused?
Not confused, only curious.
tube-exorcist
Postby tube-exorcist » 08 Aug 2011, 14:23
One additional question for the guru:
When the duty-cycle of a square wave changes, does it have an effect on the sound or not ?
tube-exorcist
Postby pedalguru » 08 Aug 2011, 14:26
jreeves47 wrote:Dude it's a silicon tonebender
Dude, you started this whole exchange by making claims you ultimately could not substantiate.
Still can't, I take it?
Then why don't you dazzle everybody here: be a man about it and just admit that you have no proof to back up your claims, and publicly withdraw them?
Or you can just resort to name calling and diversion and hope the whole thing just goes away and people forget that you were called out and was unable to provide a meaningful response.
pedalguru
Postby culturejam » 08 Aug 2011, 14:33
Aren't you the guy that was asking about a simple loop box?
viewtopic.php?t=13813
culturejam
Has thanked: 466 times
Have thanks: 584 times
Postby Seiche » 08 Aug 2011, 14:37
pedalguru wrote:Is it that you share ideas but don't sell designs shared here with the general public for financial gain, or do you have a company that builds and sells the designs of others?
Is there maybe another possibility? :roll:
pedalguru wrote:Just a thought
sorry, maybe you should keep your thoughts to yourself next time. thinking doesn't seem to be one of your strengths.
pedalguru wrote:And please enlighten us mictester: How well does the original MKII tonebender circuit work if you simply replace the germanium transistors with silicon transistors?
Please explain why "not too well" Mr. Guru, you seem to be quite knowledgable on the subject. Possibly defending your awesome proprietary design?
how about this? It doesn't work? A Tonebender seems to be military or spaceage technology if the same principals applied to make a si fuzz face work don't apply here. It's magic surely.
Seiche
Has thanked: 257 times
Have thanks: 207 times
Postby culturejam » 08 Aug 2011, 14:41
Oh well now, this sure does explain things. Looks like our guru shares an IP with another recent poster. :secret:
culturejam
Postby Seiche » 08 Aug 2011, 14:43
culturejam wrote:Oh well now, this sure does explain things. Looks like our guru shares an IP with another recent poster. :secret:
Seiche wrote:thinking doesn't seem to be one of your strengths.
:roll:
Seiche
Postby tube-exorcist » 08 Aug 2011, 14:43
pedalguru wrote:Dude, you started this whole exchange by making claims you ultimately could not substantiate.
Mr. Guru, did you start now to talk with yourself ?
I am still waiting for your answers....
tube-exorcist
Postby jreeves47 » 08 Aug 2011, 14:54
I PUBLICLY WITHDRAW MY CLAIMS whatever they were. Now run along and don't make me draw claims on you again!
jreeves47
Postby pedalguru » 08 Aug 2011, 15:07
Glad you bring this up, because it basically is all you have been able to present to defend your position so far.  Ask yourself:  Does the original germanium design have a resistor from collector to base?  No.  Does the original germanium design have a resistor between emitter and ground?  No.  Would this somehow change the input impedance from the point of view of the guitar?  Yes.   Do things such as input impedance affect how a pedal sounds?  Yes.  Therefore, is it the best possible solution to replacing the germanium input transistor with a silicon transistor, if the objective is to make it sound exactly the same?
I'll leave you to figure that out for yourself.
pedalguru
Postby tube-exorcist » 08 Aug 2011, 15:23
pedalguru wrote:Glad you bring this up, because it basically is all you have been able to present to defend your position so far.  Ask yourself:  Does the original germanium design have a resistor from collector to base?  No.
Yes, a virtual, it is inside the transistor. Ever heard about leakage ?
Yes, the emitter resistor will increase the input impedance. If it gets too high for you, you can simply add a resistor with the desired impedance at the input.
see above
I figured, and now I have another question:
If the input stage is so important for the sound, why don´t you ommit the Fuzz Face part ?
And yes:
If the collector voltage of the second transistor in the Fuzz Face part varies, does that have an effect on the duty cycle ?
Maybe you could be so kind and make some tests on an rectal-chanel pcb ? It is easy, you only need a cold-spray, a heating gun and an oscilloscope. Or should I do that for you and present the results ? I only don´t want that you will say: That´s a different circuit.
So what do you think will have more effect on the sound:
The input impedance, or the duty cycle of the square wave generated by the Fuzz Face part ?
tube-exorcist
Postby pedalguru » 08 Aug 2011, 16:16
Yes. But I've also heard that semiconductor junction leakage is usually represented as a current source, not a resistor. There is a big difference. Have you heard?
You think so? What about the non-linear input impedance presented by the BE junction? How do you compensate for the fact that the emitter resistor has linearized the transistor input impedance with yet another linear impedance?
The theory of operation of the input transistor is large signal. Your suggestion of a small-signal compensation will not hold up in practice.
All this harping on about the temp stability of the FF section: Be careful, because another position taken by your compadres is that Si circuits are already temperature stable enough that making claims of temp stability are redundant.
Are you now suggesting that there may actually be something to it?
Look, I think we can at least agree that the amount of drift for a Si FF is negligible for all practical purposes. You could add circuitry to make it sensibly zero drift, but you would be well beyond the limit of diminishing returns, and in this particular instance mictester would have a good case to claim the effort was a waste of parts and battery current.
pedalguru
Postby mictester » 08 Aug 2011, 16:18
pedalguru wrote:BTW, the Fuzz Face part is NOT temperature stabilized, only the first transistor stage, can you tell me why ?
Yes - because you got the resistor values wrong!
What a maroon!
mictester
Has thanked: 33 times
Have thanks: 803 times
Postby pedalguru » 08 Aug 2011, 16:22
What a maroon!
Er, I think you'll find I didn't actually write that to begin with.
Who's the maroon now?
pedalguru
Postby coldcraft » 08 Aug 2011, 16:24
this is true. pedalguru just recently learned how to properly quote.
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Return to Announcements and Forum Rules
Users browsing this forum: No registered users and 7 guests
