IMPORTANT -- how to save your account from deletion
Have a look here for general information about the forum, rules and announcements.
Postby modman » 10 May 2012, 13:08
  • Make a friendly introduction post - accounts with at least 1 post will NEVER be deleted
  • I you don't post, visit at least once a year. Postless accounts unused from 1y+ will be deleted.
  • If you create a new account, activate it within 2 days. New account not activated within 2 days will be deleted, because the majority of these a spam accounts.
  • Choose a username that can only be created by a human. Avoid numbers.
Freestompboxes.org in approach of its 5th birthday has:
+175,000 posts
+38,000 signups
+23,000 active accounts
+12,000 subject topics
+5,000 contributing (posting) users
+3,000 visiting members this week
+150 users logged in during the last 15min
+25 new members per dag (excluding spambots)
I should say this sounds impressive, but the sql engines seem to be doing fine. Still some cleaning out of unused accounts should be done, because of the massive amount of spamaccounts. Most of them don't succeed in getting their accounts activated, but clog up the database for no reason. It more the extended forum structure -with different sections- that turned out a bit unstable a few months back.
We should keep on emphasizing the importance of keeping the attachment file size. No black/white schematic needs to be 600k. But it's mostly those 1MB direct from the camera gutshots that are dragging us down.
Thanks everyone for taking this in account.
Johan
For this message the author modman has received thanks: 7
culturejam (11 May 2012, 15:57), Duckman (12 May 2012, 08:35), Fredenando (10 May 2012, 17:09), Groovenut (11 May 2012, 22:31), Nocentelli (11 May 2012, 17:03), rocklander (11 May 2012, 00:41), sinner (11 May 2012, 12:28)
Has thanked: 3110 times
Have thanks: 560 times
Re: IMPORTANT -- how to save your account from deletion
Postby phatt » 11 May 2012, 12:16
Re big pictures;
I'm a member of an Aussie Forum and they have canned direct posting of pics.
Not that I'm in favor as I don't use Pbucket or like.
Maybe some of those *in the know folks* could explain how simple it is to re-size camera shots.
FWIW, I use Irfanview to edit pics. Heck I'm a computter dumb-ass and I worked out Ifanview. :thumbsup :blackeye
Phil.
For this message the author phatt has received thanks:
modman (11 May 2012, 20:57)
phatt
Have thanks: 264 times
Postby Greenmachine » 11 May 2012, 16:56
I resize pictures using a PC running Picasa (free photo editor I think). Click on "Export" under the picture viewer and resize to anything under 700 pixels or so. I'll go even smaller than that from now on now that I see it has an effect on the site. Thanks Johan.
:thumbsup
For this message the author Greenmachine has received thanks:
modman (11 May 2012, 20:58)
Greenmachine
Has thanked: 102 times
Have thanks: 19 times
Postby IvIark » 11 May 2012, 17:05
In IrfanView, go to:
Image > Resize/Resample
Choose a new width like 800 pixels, and if you have the "Preserve Aspect Ratio" option ticked, the height will be automatically filled in for you whilst keeping the image at the correct ratio.
Experiment with the "Apply sharpen after resample" option, personally I think the results look better without this autosharpening which tends to make the final image more grainy, but you may have better results than me.
Make sure that for "Size Method" you have "Resample (better quality)" selected and then just click ok to perform the resize. Save as a new image so you can keep the bigger original as a master copy.
For this message the author IvIark has received thanks:
IvIark
Has thanked: 668 times
Have thanks: 678 times
Postby Dirk_Hendrik » 11 May 2012, 17:44
phatt wrote:. Heck I'm a computter dumb-ass and I worked out Ifanview.
Persoally I cannot imagine computer life without Iview. When setting up a new system it's one of the first applications to be installed. :wink:
Reason: added link
For this message the author Dirk_Hendrik has received thanks:
modman (11 May 2012, 20:56)
Has thanked: 253 times
Have thanks: 1014 times
Postby CHEEZOR » 11 May 2012, 19:15
Sorry, I totally clog up the tubes with large gut shots... :oops: I'll try to post them elsewhere.
CHEEZOR
Has thanked: 71 times
Have thanks: 90 times
Postby modman » 11 May 2012, 20:55
CHEEZOR wrote:Sorry, I totally clog up the tubes with large gut shots... :oops: I'll try to post them elsewhere.
Please don't stop, just adapt to a lower resolution.
Postby rocklander » 11 May 2012, 22:08
this, but for me it's photofiltre
rocklander
Has thanked: 1580 times
Have thanks: 289 times
Postby CHEEZOR » 11 May 2012, 22:12
No, I just meant that I would post links for higher resolution gut shots. I definitely wont stop. :)
CHEEZOR
Postby modman » 12 May 2012, 07:03
As far as schematics go, the below should be a rule of thumb:
analogguru wrote:Please DON´T save the schematic as .jpg.
USE INSTEAD black/white .GIF or .PNG !
The schematic drawing will stay sharper and the file will be smaller.
analogguru wrote:Anyhow here is the .pdf converted to .gif - first with ghostscript to .bmp and then with XnView (Freeware) to .gif - to show you what I mean.
resolution .jpg: 1123 x 793 (~ 100 dpi)
file size .jpg: 143.092
resolution .gif: 3508 x 2479 (300 dpi)
file size .gif: 95.015
viewtopic.php?f=1&t=6946&p=74943#p74943
analogguru wrote:1.) look for the freeware Xnview, it does all you need and is free and fast.
2.) Never use .jpg to save a schematic, the file will be huge and the lines will become unsharp.
3.) use instead .gif or .png - the size of the dfile is much smaller and there doesn´t occur interpolation like in jpeg (what makes the drawing unsharp).
4.) never use true-color - reduce the file to 16 greyscales/colors or better black/white only. A schematic 210mm x 297mm with 300dpi resolution should be approx. 70kb as a .gif-file.
5.) If you want to reduce the dpi it is easily done with Xnview:
In the menu go to "picture"...."change size" and you have got it.
viewtopic.php?f=6&t=1674&p=20574&#p20574
Postby salocin » 14 May 2012, 02:40
modman wrote:We should keep on emphasizing the importance of keeping the attachment file size. No black/white schematic needs to be 600k. But it's mostly those 1MB direct from the camera gutshots that are dragging us down.
Johan, have you considered running a script over the attachments to resize/resample at lower quality? A PHP script using GD library would do the trick.
salocin
Have thanks: 7 times
Return to Announcements and Forum Rules
