Good buffer to place at the beginning of pedalboard
Re: Good buffer to place at the beginning of pedalboard
Postby sinner » 20 Oct 2012, 00:39
Roast7 wrote:
Advice for other projects in stripboard, in addition to the layout IvIark posted???
Am I at your ignore (foe) list already?
I listed links to two vero projects on my website
Has thanked: 1240 times
Have thanks: 1100 times
Postby roseblood11 » 20 Oct 2012, 00:57
roseblood11
Has thanked: 350 times
Have thanks: 310 times
Postby ppluis0 » 20 Oct 2012, 01:50
FiveseveN wrote:Why? That has absolutely none of the advantages of a 50 cent modern buffer.
At least is a good starting point to try something based on tubes. 8)
ppluis0
Has thanked: 43 times
Have thanks: 85 times
Postby FiveseveN » 20 Oct 2012, 06:15
A better starting point is something where tubes get a chance to distort and actually make a difference, but that's not the subject of the thread. The subject is "a good buffer". Valves do not make good buffers, certainly not better buffers. You'd just be asking for the trouble of a high-current heater and high-voltage plate supply so you can have something glow on your pedalboard. Spare yourself, buy a light bulb.
FiveseveN
Has thanked: 132 times
Have thanks: 52 times
Postby biliousfrog » 20 Oct 2012, 10:42
Any opinions on the Lehle buffers? I've heard very good things but haven't had a chance to try them.
biliousfrog
Have thanks: 10 times
Postby Roast7 » 20 Oct 2012, 11:17
Sinners sorry, I thought you had placed two opamp layout lol: P
I've noticed is that, there are more projects stripboard for opamp, than to jfet.
Roast7
Have thanks: 8 times
Postby IvIark » 20 Oct 2012, 12:01
Roast7 wrote:I've noticed is that, there are more projects stripboard for opamp, than to jfet.
That's just because there are more opamp buffer variations than JFET. The basic buffer circuit is a generic source follower, and so although there are some variation in passive values or the way the JFET biases, the basic concept is textbook electronics. The way the manufacturers use opamps seems to vary more, as you can see by looking at the buffer options such as the Klon, or BJF buffer out of the Ruby Red booster.
IvIark
Has thanked: 668 times
Have thanks: 682 times
Postby Roast7 » 20 Oct 2012, 14:17
By the way I put here I tried to do the layout, the buffer toast Black
is my first, I did with the help of this image:
If someone can confirm that everything is okay was very good.
Roast7
Postby ppluis0 » 20 Oct 2012, 23:17
FiveseveN wrote:Spare yourself, buy a light bulb.
Hi FiveseveN,
Today I received my last shipment of NOS tubes to add to the 600 or 700 that I already have stored:
Now I will try to acquire some decent light bulbs also because I still have some money to spend (these 200 tubes were found VERY cheap), so thank you very much for your advice... :thumbsup
ppluis0
Return to Circuit Blocks
