jacks problems
jacks problems
Postby copachino » 23 Mar 2014, 21:52
hi all, i think i have problem with my jacks, i can build anything, and the sound its only ground, but voltages are ok, in everything i have made, i have build many pedals, so i dont doubt my soldering skills, but i have tried something that mayme doubt of my jacks, if i use a two jacks, and solder a lead in the tip of the jack and the join tip to tip, i cant get any sound, as far as i know it should work but i dont gat any sound, its that normal?? or my jacks are bad??
copachino
Have thanks: 6 times
Re: jacks problems
Postby davent » 24 Mar 2014, 04:37
Need to connect the two jacks grounds as well.
dave
davent
Have thanks: 9 times
Re: jacks problems
Postby copachino » 24 Mar 2014, 13:14
davent wrote:Need to connect the two jacks grounds as well.
dave
if there its not circuit can i ground them anywhre??? as long as the both jacks share the same ground, or am i missing someting??
copachino
Re: jacks problems
Postby DrNomis » 24 Mar 2014, 14:29
If you solder a wire from the tip connection of one jack to the tip connection of the other jack, provided that the two sleeve conections are connected together, you should get sound, if you aren't getting sound there could be one of three possibilities:
1, the connection from one tip to the other is broken somewhere.
2, There's a short-circuit to the sleeve connections somewhere.
3, The connections between the two sleeves could be broken somewhere.
There's a chance of all three possibilities too, check for continuity where there should be continuity with a multimeter..... :thumbsup
DrNomis
Has thanked: 123 times
Have thanks: 397 times
Re: jacks problems
Postby copachino » 24 Mar 2014, 18:44
thanks i will try this later after work, so i should join the sleves right??
copachino
Re: jacks problems
Postby DrNomis » 25 Mar 2014, 00:43
copachino wrote:thanks i will try this later after work, so i should join the sleves right??
Yes, they normally connect to circuit ground...... :thumbsup
DrNomis
Return to Absolute Beginners
