Will this mod work on a tonebender schematic?
Postby carabinerX » 22 May 2014, 23:05
This is my first pedal, after reading some great information given to me about muff pedal circuitry, ive tried to adopt some of the techniques and values to shape the sound. I dont know much about effects in regards to the voltage changes across the board, by changing some values and adding a diode do you foresee any serious issues with my changes, or have any tips/suggestions? Thanks!
carabinerX
Re: Will this mod work on a tonebender schematic?
Postby carabinerX » 23 May 2014, 00:15
sorry guys, here is the image without downloading anything
carabinerX
Postby carabinerX » 23 May 2014, 01:15
My main concern here is the diode 'clipping' section, as ive been informed the original diode may be there just for temperature moderation and may not have an audible effect to put a clipping stage there, but I was thinking it may raise the leakage threshold governing Q3 giving more bite to the trim which, hopefully, will expand the potential tone range/effect....any thoughts here?
carabinerX
Postby DrNomis » 23 May 2014, 08:34
One of the two diodes (D1 and D2) will shunt most of the signal to ground, so you might find that you'll lose a bit of gain..... :thumbsup
Has thanked: 123 times
Have thanks: 399 times
Return to Absolute Beginners
