splice42 wrote:Not sure why no one replied to you, so I registered to give you an answer.
If you want the sweep of the pots to be different, I suggest you get different pots. For the gain, you should have a 100k linear (B100) pot. If you want to only use half of that range, get a 50k linear pot instead. The tone is a 25k linear pot, so if you want to use half, you'd need a 12.5k linear pot but that doesn't really exist that I know of. 10k linear might fit the bill for you if you don't really use the very top end, or you might just want to put in a 2.2k resistor in between the middle lug and the pad on the board, making the sweep 2.2k to 12.2k, cutting off the very bottom range of the pot which hopefully you don't use.
This is all off the top of my head but it should work for your purposes.
