electronic parts in garage during winter
Postby jimiguitar » 17 Nov 2014, 17:00
is it safe to keep electronic parts in garage during winter ? or how cold can you keep them before they are ruined
jimiguitar
Re: electronic parts in garage during winter
Postby grrrunge » 17 Nov 2014, 17:04
jimiguitar wrote:is it safe to keep electronic parts in garage during winter ? or how cold can you keep them before they are ruined
That would usually be specified in the component datasheet. How cold does your garage get?
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby jimiguitar » 17 Nov 2014, 18:28
looks like i'am safe all of the data sheets so far that i saw say -55c which is about -65f it dont get colder than single digits at the worst winters we had
jimiguitar
Postby deltafred » 17 Nov 2014, 18:50
I would be more worried about condensation causing corrosion than the actual temperature.
I know condensation in my garage can be pretty bad when the temperature changes rapidly.
deltafred
Has thanked: 389 times
Have thanks: 263 times
Postby Duckman » 17 Nov 2014, 21:43
deltafred wrote:I would be more worried about condensation causing corrosion than the actual temperature.
I agree. Unless you live near the Poles or in some very extreme climatic condition, you must concern more about how humidity work in metal parts of components, than temperature.
Soldering doesn't like oxidation. :secret:
Duckman
Has thanked: 368 times
Have thanks: 131 times
Return to Absolute Beginners
