I don't have that exact component: equivalents
Spazzmatazz
Post by Spazzmatazz »
I've got a few pedal project on the way, but when I go shopping the components, I always have some problems. I want to know parts that would work instead of others.
any substitution or equivalence to:
J201
2N5952
thanxs
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
They're both JFETs so you could go for 2N5457, 2N5458, 2N5459, 2N5484, 2N5485, 2N5486, MPF102. These all have the same DSG configuration as the J201 but would have to be turned 180º if used as replacements for the 2N5952 (GSD).
You could also use something like the 2SK117 or 2SK170 but they are both DGS so you would have to alter the scheme to reflect that.
Spazzmatazz
ok man!!
let's see if my store have them.
thank you.
Spazz
AbuseArt
my favorite amplifier: laney lc15
Completed builds: Vox Clyde McCoy
Rebote Delay 2.5
Tube Screamer TS-808
Exotic AC Booster
Marshall Guv'nor
Big Muff Pi
Big Muff Triangle
EH Pulsar
Joe's Simple Overdrive
Post by AbuseArt »
I'm just buying capacitors and pots for a Rebote 2.5 Delay and Tubescreamer.
1. for example, both units demand 25k pots. Can I use 22k instead and add parallel 3k resistor to one of its leg?
2. are capacitancies as important as resistances? Rebote needs 0.027uF. The closest value they have is 22nF. Would it work? I know that distortion circuits doesnt need big precision, today I made Big Muff using not perfect values but it still sounds like brand new box from Electro Harmonix ;)
Thanks in advance
briggs
Has thanked: 27 times
Been thanked: 128 times
Post by briggs »
A lot of the time small parts subs won't make any audible difference. I made a Rebote with barely any matching parts - you will be fine with the alterations you have mentioned, it'll work fine, maybe sound slightly different. Pot taper's must be matched to get the same response and RC filters where one value is alters must be compensated to work at the same corner freq as before. But the circuits will still function fine.
I am Klon.
