Hi guys!
I ve the some problem of most of you, i ve a mxr flanger clone with a bad sad1024 probably. I ve decided after many years to' resuscitate it...i ve bought a mn3007 and i build a daughterboard following the layout founded here..
I ve seen the new Schematic to fill mn3007, but im not surehow to' link daughterboard to' mxr pcb...someone could explain it a little more simplified..?
Thank you in advance!
Another queztion: i ve not found cd4013 & cd4049( buffer for retrofit) but only hcf4013 & hcf4049..
I ve dead that tese ic want 5v supply ...am i right?
How can i modify circuit to' fit these ic's..?
