bipolar supply versus higher voltage supply
Posted: 19 Apr 2012, 09:46
by dorothegreat
I've read that both increases headroom but most are from higher voltage supply. what really are the pros and cons between the two? which is better? thanks
Re: bipolar supply versus higher voltage supply
Posted: 22 Apr 2012, 06:40
by ansil
depends on the circuit but i have been playing around with amp style circuits in pedal form and found even at higher voltages it seems half the wave is clipped more when i utilize the standard vbias method. but i am trying the same supply but plus and minus and find a more reliable wave form. but i am just scratching the surface of my research here.
