LED choice for 3PDT true bypass stomp wiring
Postby fishfude » 13 Jun 2012, 14:17
Hi Guys,
I was thinking of using ultrabright 5mm LEDs for my power indicator with my 3PDT true bypass stomp wiring. I've seen 4.7k quoted for normal LEDs. How do I calculate what I should use instead? Does its luminosity (1000mcd vs 4500mcd) affect things? Are there any other considerations (other than price) I should be taking into account?
As always, many thanks,
ff
fishfude
Has thanked: 42 times
Re: LED choice for 3PDT true bypass stomp wiring
Postby Seiche » 13 Jun 2012, 23:00
it doesn't really matter. all a matter of taste and how bright you like 'em. 5.6k should be fine. go lower if you want it brighter and higher (10k) if you'd like it less retina damaging.
Seiche
Has thanked: 241 times
Have thanks: 184 times
Postby Nocentelli » 13 Jun 2012, 23:08
I find you can go 15-18k and still see it easily with the high efficiency/superbright ones: I always understood a higher value resistor made switch pop less likely.
fishfude (18 Nov 2013, 00:27)
Nocentelli
Has thanked: 871 times
Have thanks: 839 times
Postby lofi73 » 13 Jun 2012, 23:41
I have used 18k on some of the really bright ones.You can do a quick simple test by connecting/touching the led and resistor in series to a 9v battery
lofi73
Postby Seiche » 15 Jun 2012, 00:49
or wire a pot in series with the led, set it at the brightness you prefer and then measure it.
For this message the author Seiche has received thanks:
fishfude (18 Nov 2013, 00:28)
Seiche
Return to Diodes & LEDs
