how to get 200v 100mA or 1A rectifier bridge using 1n400x?
Postby leftfingaz » 06 Nov 2013, 16:53
how to get 200v 100mA or 1A rectifier bridge using 1n400x? help. this is for my solid state amp without using diode bridge. here is the schematic http://www.redcircuits.com/Page158.htm
leftfingaz
Re: how to get 200v 100mA or 1A rectifier bridge using 1n400
Postby Dirk_Hendrik » 06 Nov 2013, 17:47
With the link I really don't get the question. What is it exactly that you want to do?
Has thanked: 255 times
Have thanks: 1024 times
Postby leftfingaz » 06 Nov 2013, 18:59
Dirk_Hendrik wrote:With the link I really don't get the question. What is it exactly that you want to do?
i cant find a 200v 100ma package rectifier bridge. its look like this
how can i replace it with 1n400x diode? can i use 4 1n4003?
leftfingaz
Postby galmar » 06 Nov 2013, 19:13
No, 1N4003 are rated for 140V of reverse voltage. You should go with 1N4004 at least. I would use anything between 1N4005, 1N4006, 1N4007. If there is no difference in price, I would go with 1N4007.
If you also don't mind getting them or paying a bit more cents for them, go with UF4004-UF4007. :)
For this message the author galmar has received thanks:
leftfingaz (07 Nov 2013, 01:51)
galmar
Have thanks: 10 times
Postby Dirk_Hendrik » 06 Nov 2013, 21:36
Ah! Now I get it
The transformer required is a 2*25 volts. That means a 1N4001 will do. Therefore one can wonder why a 200v rectifier is in the parts list in the first place. Personally I'd opt for a 1N5400 type diode. Plenty of reserve in case of current peaks.
Postby galmar » 06 Nov 2013, 22:54
Oops, I didn't notice the schematic. :)
Yes, so much reverse voltage isn't necessary. Dirk is spot on about going on the 54XX series. You can again buy a UF5402 as a better replacement if you don't mind the extra cents.
By the way, I have a 1N5400 at hand and various 1N400X ones. The 1N400X are the usual size we all know, but that 1N5400 - it is big like a mouse! :P
galmar
Postby leftfingaz » 07 Nov 2013, 01:51
thank you for your help :) cheers
leftfingaz
Return to Diodes & LEDs
