how to get 200v 100mA or 1A rectifier bridge using 1n400x?
Posted: 06 Nov 2013, 15:53
by leftfingaz
how to get 200v 100mA or 1A rectifier bridge using 1n400x? help. this is for my solid state amp without using diode bridge. here is the schematic
http://www.redcircuits.com/Page158.htm
Re: how to get 200v 100mA or 1A rectifier bridge using 1n400
Posted: 06 Nov 2013, 16:47
by Dirk_Hendrik
With the link I really don't get the question. What is it exactly that you want to do?
Posted: 06 Nov 2013, 17:59
by leftfingaz
Dirk_Hendrik wrote:With the link I really don't get the question. What is it exactly that you want to do?
i cant find a 200v 100ma package rectifier bridge. its look like this
how can i replace it with 1n400x diode? can i use 4 1n4003?
Posted: 06 Nov 2013, 18:13
by galmar
No, 1N4003 are rated for 140V of reverse voltage. You should go with 1N4004 at least. I would use anything between 1N4005, 1N4006, 1N4007. If there is no difference in price, I would go with 1N4007.
If you also don't mind getting them or paying a bit more cents for them, go with UF4004-UF4007.
Posted: 06 Nov 2013, 20:36
by Dirk_Hendrik
Ah! Now I get it
The transformer required is a 2*25 volts. That means a 1N4001 will do. Therefore one can wonder why a 200v rectifier is in the parts list in the first place. Personally I'd opt for a 1N5400 type diode. Plenty of reserve in case of current peaks.
Posted: 06 Nov 2013, 21:54
by galmar
Oops, I didn't notice the schematic.
Yes, so much reverse voltage isn't necessary. Dirk is spot on about going on the 54XX series. You can again buy a UF5402 as a better replacement if you don't mind the extra cents.
By the way, I have a 1N5400 at hand and various 1N400X ones. The 1N400X are the usual size we all know, but that 1N5400 - it is big like a mouse!
Posted: 07 Nov 2013, 00:51
by leftfingaz
thank you for your help
