OUTPUT JACK SUCKING UP THE TONE
Re: OUTPUT JACK SUCKING UP THE TONE
Postby Hides-His-Eyes » 20 Oct 2010, 08:46
So you used an audio probe and found your problem was between the output and the output jack?
Hides-His-Eyes
Has thanked: 53 times
Have thanks: 84 times
Postby DrNomis » 21 Oct 2010, 15:14
wireconnect wrote:hello people...
i build the zombie but with i plug it and use ..the the output of the zombie became muddy..,its sounds like you have a treble knob putting it to zero..,its not clear...its muddy.. then i found out the problem is in the output jack...
Why is it that output jack behaves like that?? normally...jacks do not behave like that based on my other d.i.y..any body here knows this kind of problem??? tell me why?? :scratch:
thank you
Possibly a capacitive coupling effect to ground,but that would require at least say 1 nano farads,but then maybe the output impedance is being loaded down by something inside the output socket,have you tried measuring from the tip connection to ground using a multimeter?,when not wired up to anything,there should be an open-circuit between the output socket's tip connection and ground,if you get something like 10k or less,that can load down the output a bit,causing the loss of treble you are experiencing.... :)
I think your faulty output socket is causing a partial-short to ground.... :)
Has thanked: 123 times
Have thanks: 401 times
Return to Debugging
