Multiface/Fuzz Face debugging
I tried to make a fuzzface on a perfboard, based on what I could find on those two websites :
http://www.home-wrecker.com/multiface.html
http://geofex.com/Article_Folders/fuzzface/fffram.htm
I put sockets for most of the parts. I got no sound going through the beast.
I wonder if the layout I made has any mistakes. Does someone sees nonsense in it ? (I'll burn a candle for him / them)
Thanks !!
here it is :
Thanks !!
here it is :
- mysticwhiskey
What transistors did you use? And what's that component marked 'XXX' - is it a resistor?
Hi,mysticwhiskey wrote:What transistors did you use? And what's that component marked 'XXX' - is it a resistor?
the transistors I used were BC548C for Q1 and 2N2907A for Q2
the XXX is just a jumper on sockets for yet, but I'll try with a resistor
thanks
- mysticwhiskey
Hmmm, 2N2907A is a PNP transistor, whereas your circuit is designed for NPN's.
Thanks mysticwhiskey, that's great, I just hadn't checked that before to plug it...mysticwhiskey wrote:Hmmm, 2N2907A is a PNP transistor, whereas your circuit is designed for NPN's.
It's working now, sound is going through, and I have fuzz.
I have issues now with the 5K fuzz pot... Aaargh, it's one of my first circuit, and I just feel it now.
Does anything seem wrong in the layout ?
thx
Actually I plugged the fuzz pot according to the multiface layout
http://www.home-wrecker.com/multiface-perf.png
I'll try with the geofex one (Lug 1 on the ground, Lug 2 on the filter cap, Lug 3 on the emitter of Q2)...
I'll tell you next days, when I could have done this big work
