TS808 works with battery not with AC adapter
Postby Dave Simpson » 29 Jan 2008, 18:38
I have a TS808 re-issue that will work with a battery but nothing when using an AC adapter. :cry: What should I check first? The diode in the power section? If someone can give me some tips to try I'd appreciate it.
Dave Simpson
Postby alteredsounds » 30 Jan 2008, 00:19
I'd stick your meter across 1st the adapter and make sure its 9v and correct polarity and working, 2nd have a look at the socket in the pedal, see if you can get a 9v reading across where it goes to the board, maybe the socket is broke? If it works from a battery there is no reason why a correct polarity 9v dc adapter wont work.
alteredsounds
Have thanks: 6 times
Postby bajaman » 30 Jan 2008, 00:26
check the adaptor - AND - does it have the right size dc socket plug on it ???
If it has a larger hole in the centre of the plug it will not make contact with the pin - should be 2.1mmm plug!!!
If the battery works then the pedal socket is okay :wink:
Has thanked: 443 times
Have thanks: 1515 times
Postby bajaman » 30 Jan 2008, 00:29
If it is an AC adaptor - it will not work. You need a DC adaptor with a negative centre 2.1mm female socket plug on the end ( preferably 9v DC regulated too)
Postby Dave Simpson » 30 Jan 2008, 18:32
I went over the solder points under the power jack and it works. Must have been a bad solder point from the factory. :D
Thanks for the replies anyway. :wink: Should have checker that first. :oops:
Dave Simpson
Return to Debugging
