I've been using little 62mA axial fuses in some of my builds (better a blown fuse than a knackered power supply should it develop a short). They work well and the few ohms resistance they add helps filter power supply noise. However one has blown in a super fuzz and I can't see the reason. If I short the blown fuse the pedal powers up and works fine. I've been using a decent regulated 9V supply and battery.
The SF only draws a 2-4mA in normal operation, so the only thing I can think of is switch on transients (which I don't know an awful lot about) as everything looks fine. Is that likely?
Blown fuse
- boblob
- PokeyPete
I believe your assessment is correct. Assuming that your build is correct,
I would venture to guess that the cause is the filtering cap. I looked up a
schematic and it showed a 100uF capacitor. This capacitor is essentially a
dead short upon power up. It charges quickly, but still causes a large
momentary surge of current when first powered up. It discharges through
the load resistance quickly after being powered down, and will surge each
time it is powered up. The larger the cap, the longer time it takes to fully
charge. The resistance between the cap and the power supply will also
lengthen the charge time. This is why in many circuits you will see "Slo-blo"
fuses being used....they can better survive the initial surge.
–Hunter S. Thompson
–Hunter S. Thompson
- boblob
Thanks man. Always good to get a second opinion.
I think little axial leaded slo-blo fuses are difficult to get - might use a small value fusible resistor instead. That should provide decent short circuit protection and easily handle the inrush.
