I've built ROG Umble pedal and it has knocked a few other Dirt boxes off my board. My only problem is it gets what I would call excessive hum. Is there any way to eliminate or tame it down some?
I did do a search and I found some info about using a 100 ohm resistor followed by a 100uf Electro to ground at the start of the +9v in?? Would something like that work? If so where can a learn a bit more about this type of thing?
To let you know I followed the Schematic and perfboard layout on ROG website for it.
Let me know if any pics of the build are needed as well, I can have them in a few days?
Thanks for your time and any help,
Travis
How do I fix a hum problem?
- Paul Marossy
It may be that you have hum getting into your system elsewhere and any high gain pedal will pick it up and amplify it a lot. It's happened to me many times.
Once I had a patch cord running too close to a wall wart, and you couldn't hear any hum until you switched on a high gain distortion pedal. When I re-routed that patch cord, 90% of the problem went away.
