BlackFace A135 Preamp
All about tubes, in amplifiers and in stompboxes.
Postby ezugaru » 26 Mar 2012, 18:20
Hi guys, I've been here for a while, reading, and reading, and reading, and giving opinion some times, since I don't hink I can give the right answer some times.
Well, I am a bass player, and Iove the old sound of the bassman amps (blackface), so I wanna built a 2 channel blackface preamp. This is the schematic I choose:
Here are my first concerns:
1.- Is there any problem if I just want to use inputs 1 & 3? I want two channel 'cause I think that a 2nd channel with cranked controls will drive the signal and give it a bit of vintage dirt.
2.- And the MOST IMPORTANT, How to feed that circuit segment, I'm very confused trying to understand how the Transformer deliver the voltage there since I see many connections from the transformer, I need that original transformer or may I use something different??? I've see the GTFO feeding drive tubes with a digital PSU. >.<
3.- Is there any way to use a switching method that allow (CHAN A or CHAN B) and (CHAN A and CHAN B)???
I hope I dont bother You too much with this, thanks in advance!
You are not dumb if you are a good person, is just that dumb people don't recognize the good things.
ezugaru
Has thanked: 44 times
Have thanks: 5 times
Return to Tube Technology
cron
