D*A*M - Fleshhead [traced]
- IvIark
Wow. Well no one's bought it yet, but God there are some retarded people in this world if anyone does.bootle wrote:zoikes!! 1,500 snots, that's 2,300 dollars!
http://cgi.ebay.ie/DAM-D-A-M-FLESHHEAD- ... 255a87988d
What a nobwhen you buy a Rolls Royce you dont ask how many MPG you get
- bootle
roflwhilst trying it , it has been nested on softest tissue paper 4 ply of course
I wonder did he wear white gloves when he held it too.
honestly..The screenprint had few minor blemishes on these , that is what makes them what they are
- Kollaps
- Completed builds: "boutique" + bass boost + diode selecting TS808
"Civil War" Big Muff
D*A*M Drag'n'Fly x2
D*A*M Fleshhead
Gristlizer
Upcoming and/or currently on the bench:
FrequencyCentral Murder One
AD-80/AquaPuss
D*A*M Meathead - Location: Near Los Angeles
- Been thanked: 1 time
Lol, yeah, the 4 ply tissue comment killed me. 4-ply "of course" as if we'd be fucking stupid to use anything less.
My clone may be sporatically functioning and with less than stellar transistor gains, but mine cost about $15US. Compare that with the £1550 STARTING bid (with s&h), and I'm more than okay with trade off.
Why in the blackest depths of he'll would anyone spend £1550 on a pedal? You can buy a vintage orange for that much...
- RnFR
of course!focused treble ripping to a massive blackness
keep your fucking mullards, i'll take the motorcycle.
This will be my first build from scratch. Any recommendations on getting parts? I've been looking on Mouser and just kind of going with whatever category has the most components, which i'm sure is not ideal. Also is there a quick diagram for switches on this site?
- johnnyg
Others can help with sourcing parts in the USA (guessing that's where you are if you're looking at Mouser). Look here for wiring and switching diagrams and info: http://www.beavisaudio.com/techpages/Krallum wrote:This will be my first build from scratch. Any recommendations on getting parts? I've been looking on Mouser and just kind of going with whatever category has the most components, which i'm sure is not ideal. Also is there a quick diagram for switches on this site?
No-one has made the starting bid of £1,500 yet... why not? This is theRnFR wrote:why for theKollaps wrote:
Why in the blackest depths of he'll would anyone spend £1550 on a pedal? You can buy a vintage orange for that much...of course!focused treble ripping to a massive blackness
Mullard holyest of grail OC81D
Mangle the English language why don't you in your pursuit of dirty profit? 'Holiest grail' would be figurative - but the 'of' in that statement suggests we should take it literally. Grail, I believe, comes from medieval French for dish - so this guitar pedal is the holiest of dishes. Even holier than the one Jesus drank from at the last supper. That could be construed as blasphemy I think.
Yet to break through the Space Charge
- gilmour_pugliese
hi guys!
I've built this pedal with 3 AC128 (hfe: 70 on q1, 90 on q2, 120 on q3) with a 20k trimpot on q3 collector and 50k on q2 collector. Sounds amazing but with a less sustain that I've expected... Looking the schematic I've noted that the q1 base resistor is too low compared with the some MK2 schematics (100k)... a 100k is better?
just one note: don't bias q3 at 4,5v... the pedal is fizzy and have a too low output. Increase the voltage up to 7v, and you have a more focused fuzz effect and a lot of output!
- 47185_1545993140278_1548515862_1348206_2619488_n.jpg (61.02 KiB) Viewed 2634 times
- gilmour_pugliese
EDIT: this afternoon I've spent some time tweaking the trimpots... and the results are very strange
I've used this voltage chart:
http://stompboxes.co.uk/forum/viewtopic ... 5&start=20
OC75 MkII (10K on Q1 base, 47K on Q2 collector)
Battery -9.01
Q1 c -8.50 b -0.038 e 0
Q2 c -0.13 b -0.076 e 0
Q3 c -8.29 b -0.13 e -0.08
and this:
http://home-wrecker.com/tbmk2.html
Q1 c -8.67 b -0.082 e 0
Q2 c -0.560 b -0.121 e 0
Q3: c -5.07 b - 0.563 e 0.441
So, I've biased Q2 and Q3 with DAM voltages and the pedal has a lot of output but the sustain is not incredible and the fuzz seems to be gated
After I've tried the Mindbender voltages... and now the pedal is pretty compressed and with a good note decay.
Anyone has the same issue? I've read that q3 wants to be biased at 7v, but IMHO the result is awful... no singing sustain!
Battery -9.01
and this:
- phibes
- Transistor Tuner
Ditch the trimpot on Q3's collector and stick the 8K2 back in. Change the trimmer on Q2's collector to 100K. Shoot for 6-7V on Q3's collector and you should be back into the right ballpark. No need to over-complicate it! The trimmer on Q2's collector will bias better than a trimmer on Q3's collector.
Personally I like 10K on Q1's base to ground better than 100K so I would leave that alone. 100K is too much in my opinion.
Give that a shot!
Give that a shot!
Ken
Ken
- gilmour_pugliese
Thank you phibes... but a trim on q3's collector setted on 8,2k isn't the same as a 8k2 fixed resistor?phibes wrote:Ditch the trimpot on Q3's collector and stick the 8K2 back in. Change the trimmer on Q2's collector to 100K. Shoot for 6-7V on Q3's collector and you should be back into the right ballpark. No need to over-complicate it! The trimmer on Q2's collector will bias better than a trimmer on Q3's collector.
Give that a shot!
What's the right voltage on q2's collector? IMHO 130-200mV is too low... I've the best results on the 500-700mV range
Also, I've tried a 100k on q1's base and there's a lot of fuzz... the fleshhead is without the FUZZ pot so too much gain is useless
- phibes
- Transistor Tuner
A trimmer set to 8k2 would be the same but people tend to get tweak happy whenever there's trimmers in fuzzes! The trimmer on Q2 is really all you need. Two bias trimmers in this circuit would be madness! Personally, I always leave the 8k2 in fuzzes and never fuck with it. If you look at gut shots of all the old Tone Benders and Fuzz Faces, how often have you seen that 8k2 resistor changed rather than the collector resistor on the stage before it? (Excluding Si versions obviously) I think that's something that gets overlooked.
Ken
Ken
- gilmour_pugliese
Hey man, you're in the right!!! I've sticked the 8,2k and tweaked the trimpot on Q2's collector... So, the Q3's collector is useless: if you turn up the trimpot on q2, the voltage on q3's C decrease, and viceversa... less tweak and less time to spent on biasing! Now, with a 8.5v battery, I have 0,3v on Q2's collector and 6,5v on q3's collector, and the pedal sound really goodphibes wrote:A trimmer set to 8k2 would be the same but people tend to get tweak happy whenever there's trimmers in fuzzes! The trimmer on Q2 is really all you need. Two bias trimmers in this circuit would be madness! Personally, I always leave the 8k2 in fuzzes and never fuck with it. If you look at gut shots of all the old Tone Benders and Fuzz Faces, how often have you seen that 8k2 resistor changed rather than the collector resistor on the stage before it? (Excluding Si versions obviously) I think that's something that gets overlooked.
Thank you very much for you "Tonebender Biasing" lessons!
what a nice pedal - finished mine last week. Sounds really awesome. Thank you phibes for sharing your vero-layout and your explanations on biasing the transistors. I had the same issues as gilmour_pugliese at first but tried several trannies with different hfe - huge diversity in results: went from low volume, no sustain and thin fuzz (unmachted trannies) to wreck my speakers (well matched transistors).
P.S. still feels weird to use the word tranny - since google gave me some unsettling results once
- beedotman
- SpencerPedals
FYI - That vero layout above shows a 10uF electro where a 4.7uF would be on the schematics I've seen. Was that a mistake or did they actually use the 10uF as an alternate part?
