Earthquaker Devices - Arrows  [traced]
Postby Bononoob » 11 May 2019, 20:02
So a buddy lent me a EQD Arrows so I traced it
Here's the Eagle Schematic and some gutshots
For this message the author Bononoob has received thanks: 5
287m (11 May 2019, 20:56), Intripped (11 May 2019, 20:44), karul (11 May 2019, 20:42), Manfred (11 May 2019, 20:32), modman (12 May 2019, 13:25)
Bononoob
Have thanks: 17 times
Re: Earthquaker Devices - Arrows  [traced]
Postby storyboardist » 12 May 2019, 03:00
You're really close. I traced this about a year ago, and the value off the resistor off the emitter in your schem is way too high. Should be 1.3k. And the 100k at the output goes to ground. If anyone needs a PCB I still have a few. Schem attached.
For this message the author storyboardist has received thanks: 2
Intripped (20 May 2019, 00:52), Manfred (12 May 2019, 03:31)
storyboardist
Has thanked: 69 times
Have thanks: 192 times
Postby storyboardist » 12 May 2019, 04:23
Aw heck, here's vero, perf, and etch layouts too.
lborl (12 May 2019, 14:13), Manfred (16 May 2019, 01:28)
storyboardist
Postby Bononoob » 12 May 2019, 12:48
Damn how did I mess this up
Anyway thank you for the corrections and boards that's awesome
storyboardist (13 May 2019, 03:40)
Bononoob
Postby FeVeR2112 » 15 May 2019, 18:00
What does the R2 100R resistor do here? Seems unnecessary.
FeVeR2112
Has thanked: 22 times
Have thanks: 34 times
Postby guiddruid » 15 May 2019, 21:14
FeVeR2112 wrote:What does the R2 100R resistor do
Limit current through D1 to ~90mA when the power is connected backwards.
guiddruid
Have thanks: 4 times
Postby FeVeR2112 » 19 May 2019, 23:25
Would you not just use the diode for polarity protection? A 4001 diode (1A) can handle pedal supply which are mostly 500mA at best.
FeVeR2112
Postby Nocentelli » 20 May 2019, 06:30
I always understood that a ~100 ohm resistor + large electro capacitor together form a filter for the power that reduces hum.
Nocentelli
Has thanked: 880 times
Have thanks: 846 times
