Fulltone - Supa-Trem
Postby Barcode » 30 Nov 2007, 02:38
Anyone have a schem or a good layout for this one? i have access to guts, but it is packed in there!
Barcode
Have thanks: 35 times
Postby bajaman » 30 Nov 2007, 08:36
Hi barcode - from what I am given to understand, it is a modified version of the Demeter tremulator - do a search it is here somewhere, or check out my Baja Trembulator project in the DIY project section of the forum for an improved variation on the demeter.
If you can take some photos of both sides of the sups trem board, i am sure someone will draw up the schematic :wink:
Has thanked: 444 times
Have thanks: 1517 times
Postby analogguru » 30 Nov 2007, 09:26
....it is a modified version of the Demeter tremulator....
It could also be that the Demeter Tremulator is a modified Supa-trem.
This would explain the (unnecessary) amplifier-stage in the Tremulator-LFO-section: Triangle/Square... what the Demeter doesn´t have....
Here some photos of genius Jim Demeter:
http://www.proguitar.de/ProGuitarPreisl ... yTour.html
(click on the photos to enlarge)
Have thanks: 116 times
Postby bajaman » 30 Nov 2007, 12:06
No way :shock: - why would Demeter copy Mike Fuller :roll: :?: - he has far more clues and class than him. Besides, on past form alone, we all know Mike to be an 'appropriator' of other peoples designs - he probably added the useless square wave option like he added the extra gain switch on his Fooldrive or tubescreamer 'appropriation"
Postby analogguru » 30 Nov 2007, 12:13
bajaman wrote:Demeter .... he has far more clues and class than him.
Yes, I can make a picture of his "class" with the useless zener-diodes..... (and some other things).
Postby bajaman » 30 Nov 2007, 12:19
AG - those zeners are there to act as limiters for the oscillator section - I found them to be uneccessary with my true sine wave oscillator design, and perhaps they are uneccessary in Demeter's design. however maybe they are there in case some fool plugs his pedal into a higher voltage than the intended 9v requirement - perhaps that is why they are there :?:
Postby bajaman » 30 Nov 2007, 12:20
...... anyway, he has a nice friendly looking smile in his photos :lol:
Postby analogguru » 30 Nov 2007, 12:28
When you can tell me what they should do witha higher voltage ?
If you operate the unit normal, you will have triangle, If an idiot plugs it into higher voltage you will get sine-wave ?
sorry, where the zener-diodes are is only a square-wave.... the triangle is on the output of the following op-amp. There can never occur a sine-wave....
But now let´s assume we wil get a sine-wav.... from a level of 5Vss or above....
This is now amplified by 20.... which means 100Vss at the output of the LED-Driver.... or you clip at the supply-voltage limits which leads to a square-wave....
So.... what the diodes should do ?
If you really want to round the triangle towards a sine have a look at the output of the LFO from the cx-3 leslie-sim.
Zvex (on the left) also has a friendly smile and nice wink:
http://www.musicgearsource.com/images/vexandalf.bmp
Hiiiiiii... It´s meeee..... Zachieeee.... visit meeee.... with your moneeeey.... :lol:
Postby bajaman » 30 Nov 2007, 12:31
perhaps james can enlighten us :lol:
Postby estragon » 30 Nov 2007, 12:49
analogguru wrote:Zvex (on the left) also has a friendly smile and nice wink:
Amazing! This thing of putting faces to names always surprises me!
Not in a million years I would have guessed from a set of pictures that Z looked like that. I always imagined he as a long-haired rocker, rather than a formal guy.
estragon
Have thanks: 5 times
Postby analogguru » 30 Nov 2007, 12:53
In that case you should visit our "stompbox-guru gallery":
http://www.phpbbserver.com/freestompbox ... stompboxes
Postby Lovepedal Detective » 30 Nov 2007, 15:58
I wouldn't use the term "formal guy" to describe zakci.
LPD
Lovepedal Detective
Have thanks: 3 times
Re: Fulltone SupaTrem
Postby gtrplaya101 » 05 Oct 2008, 19:06
Bump anyone come up with this schematic? or pics?
gtrplaya101
Re: Fulltone - Supa-Trem
Postby analogguru » 05 Oct 2008, 20:00
Are you talking about this ?:
Fulltone Supa-Trem
Fulltone Supa-Trem inside
Compare it with the Demeter Tremulator (and the schematic).
Postby Barcode » 12 Oct 2008, 18:41
analogguru wrote:Are you talking about this ?:
Fulltone Supa-Trem
cool, along with the pics below, we should be able to come up with the exact schematic, and thus the exact "differences" between this and the demeter. anyone fancy a crack at the schem?
ps - i have a board copy etched, and i am happy to distribute to anyone who PMs me, but it is technically copyrighted since it is a direct copy, so i will not post.
by the way, the resistor i accidentally hid under the big green cap when i bent it back at the board's edge is a 1M
Barcode
Postby analogguru » 12 Oct 2008, 21:15
Thanks...!
Really cool.... Now we can do a research: "Who cloned from whom ?"
Postby Barcode » 12 Oct 2008, 21:43
This should help too. I'm not good at reading 5 band codes, but all therest of the board is labeled.
Barcode
Postby gtrplaya101 » 13 Oct 2008, 16:54
I thought this thing was suppose to have photocell?
Quote:
Fulltone Supa-Trem
Tremolo Pedal with Photo-cell, Half/Full Speed Footswitch, "Soft" and "Hard" Footswitch, Internal Fine Adjust, and True Bypass
Am I overlooking it or whats the deal?
gtrplaya101
Postby analogguru » 13 Oct 2008, 17:04
Ther are only neglectable differences to the Demeter Tremulator... more on trhis later.
A picture of the offboard wiring would be appreciated to finish the schematic.
There is an optocoupler-cell in one corner - the black drop with four wires.
Postby jazzmaster » 13 Oct 2008, 17:05
its the black box in the upper right corner ;)
edit: ha, AG youre fast ;P
jazzmaster
Have thanks: 4 times
Next
Users browsing this forum: ryou and 3 guests
