Valvette Custom Drive  [traced]
Postby Ice-9 » 04 Oct 2010, 12:28
Here are some gut shots of the Valvette custom drive taken during dissasembly.
Ahh ! all gooped up
newly de-gooped
diodes have no markings, they look like germaniums
The opamp is a OPA2107AP
the fets are N channel 2N7000 used as part of the clipping circuit along with the diodes.
quite a nice sounding low gain overdrive that cleans up very nicely at minimum gain.
Ice-9
Has thanked: 141 times
Have thanks: 358 times
Re: Valvette Custom Drive - Degooped guts and Re'd
Postby culturejam » 04 Oct 2010, 14:05
Thanks for posting!
But, uh, where is the part where the pedal is "Re'd"?
I'm assuming that means "reverse engineered". :D
culturejam
Has thanked: 462 times
Have thanks: 580 times
Postby Ice-9 » 04 Oct 2010, 14:24
culturejam wrote:Thanks for posting!
Yes thats exactly what it means, I am just drawing up the schematic now to post having just double checked it. I only got this pedal delivered this morning, So this is quite fast work to take some pics and de goop and trace it, then get it all posted in a matter of a few hours. :)
You asked for it so here it is, next post
Ice-9
Re: Valvette Custom Drive - Degooped guts and Re'd  [traced]
Postby Ice-9 » 04 Oct 2010, 14:27
Schematic
VR1A and B is a dual gang pot to control the gain.
Ice-9
Postby culturejam » 04 Oct 2010, 14:35
Ice-9 wrote: So this is quite fast work to take some pics and de goop and trace it, then get it all posted in a matter of a few hours. :)
Whoops! :oops: :lol:
Nice work!
culturejam
Postby Hides-His-Eyes » 04 Oct 2010, 14:39
So is the second part of the dual ganger to reduce the effect of the diodes to ground at low gain values?
Hides-His-Eyes
Has thanked: 53 times
Have thanks: 84 times
Postby IvIark » 04 Oct 2010, 14:41
Nice work! And yet another Zendrive added to the list.
IvIark
Has thanked: 667 times
Have thanks: 678 times
Postby Ice-9 » 04 Oct 2010, 14:47
Hides-His-Eyes wrote:So is the second part of the dual ganger to reduce the effect of the diodes to ground at low gain values?
When the gain is at max the the pot VR1A is at max resistance (IC1a feedback loop) and VR1B is at minimum resistance (Hard clipping ) So yes you are correct.
Ice-9
Postby DimebuGG » 04 Oct 2010, 14:55
Hmmmm clipping section in both feedback loop and to ground sounds like the pedal is being choked!
DimebuGG
Have thanks: 161 times
Postby okgb » 04 Oct 2010, 14:58
Nice work
I don't feel bad about seeing degooped circuits when it turns out
to not be their own circuits , dual pot , anything use these in a
simular manor ?
okgb
Has thanked: 195 times
Have thanks: 41 times
Postby DougH » 04 Oct 2010, 15:09
IvIark wrote:Nice work! And yet another Zendrive added to the list.
Not exactly... Shunt diode clipping with variable resistance adj by gain control. Hammer's SWTC too.
DougH
Have thanks: 23 times
Postby Ice-9 » 04 Oct 2010, 15:31
okgb wrote:Nice work
simular manor ?
I agree, when this pedal arrived today and i seen the goop i thought good it may be something a bit special in which case i would not have posted the schematic, but after working out the schematic and it turned out pretty standard stuff then i decided to post it as this pedal cost me £130 uk. which is a lot for a circuit that is based on others and modded a bit. Thats why I posted the schematic.
Ice-9
Postby IvIark » 04 Oct 2010, 15:45
DougH wrote:Not exactly... Shunt diode clipping with variable resistance adj by gain control. Hammer's SWTC too.
No not exactly, but Supercharged Zendrive would still be a more appropriate name.
IvIark
Postby mcaviel » 04 Oct 2010, 17:32
Ice-9 wrote:I agree, when this pedal arrived today and i seen the goop i thought good it may be something a bit special in which case...
This is what i always thought about my gooped pedals, that the builder is hiding his special circuit when the truth is that he is hiding a clone.
mcaviel
Has thanked: 87 times
Have thanks: 19 times
Postby DougH » 04 Oct 2010, 17:50
Yes, it's the same theme.
DougH
Postby culturejam » 04 Oct 2010, 19:09
Ice-9 wrote:I agree, when this pedal arrived today and i seen the goop i thought good it may be something a bit special in which case i would not have posted the schematic,
Why not?
I'd much rather see a schematic posted from something creative or innovative instead of the same old crap in a different box.
culturejam
Postby Ice-9 » 04 Oct 2010, 20:29
Why not?
Yeah ! I see your point and agree, I was hoping this was going to be an interesting and innovative but its not.
Ice-9
Postby Adji » 07 Oct 2010, 20:36
Guess there is no need for my pics then hehe.
Sorry I missed all this, been busy this week.
I know the guy who makes these and I have one, I like it, really good low gain overdrive / boost. Never played an actual ZenDrive before so do not know how close they sound. I thought this was an original circuit, shame.
Adji
Postby IvIark » 08 Oct 2010, 00:33
DougH wrote:Yes, it's the same theme.
Yup. Here's the originality layout.
So the red bit is very slightly tweaked Zendrive, the yellow bit is very slightly tweaked Gain Stage Red, the green bit is the R&D effort which is a very slightly tweaked feedback loop clipping config and what must be a very slightly tweaked something!
To be fair he's not claiming any originality in the marketing copy. Yay to him!
IvIark
Postby salocin » 08 Oct 2010, 01:44
This pedal has the lamest goop ever! It doesn't even seem to hide anything, other than maybe the IC and transistor types. I can't believe they used jumpers on the circuit board either.
salocin
Have thanks: 7 times
Next
Users browsing this forum: dan.schumaker, Google [Bot] and 5 guests
